02-20-2010, 12:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 71 | 6300 SUPERDONGLE_KEY invalid[SOLVED] scan Code: Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35393301797816-9 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353933017978169 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Product: V 07.30 07-05-09 RM-217 (c) Nokia. ERROR: Missing SD BLOCK or PM corrupted ! how to fix it thank you |
02-20-2010, 12:43 | #2 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 618626 Status: Offline Sonork: 100.1592779 Thanks Meter: 61 | Read The Post And Repair Your Phone............... http://forum.gsmhosting.com/vbb/show...75&postcount=2 |
02-20-2010, 14:02 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model | |
The Following User Says Thank You to hasnain For This Useful Post: |
today i am REPAIR 3110c SUPERDONGLE_KEY invalid and Security test Faild solved 100% | gopalhot | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 05-25-2010 16:01 |
5310 SUPERDONGLE_KEY invalid![SOLVED BY USER] | TECNO_CARE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-05-2010 13:00 |
6300 SUPERDONGLE_KEY invalid! | .::intel32::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-20-2010 16:40 |
6300 SUPERDONGLE_KEY invalid! | GSMTURBO | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 01-03-2010 16:37 |
Nokia 6300 SUPERDONGLE_KEY invalid! | Qaisar Mahmood | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 11-12-2009 09:13 |
