N95 8gb "Security Test failed" plz help Hi after unlock sd invalid - repair SD than "security test failed" and "contact Retailer" tried to write back pm with sd auth. but warning: failed to write. (here the logs) Bus check log: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: D6FD8E2C2832CA2499E613967AF72CD063031506 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0BF000192ABE00587178C7DA802B9CA6787B708E ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported APE Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Original Imei: 35482902977768 Original Product code: 0558166 Bluetooth ID: 002109E2DE84 WLAN ID: 002109F220C4 Phone Type: RM-320 (Nokia N95 8GB) SW Version: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Imei plain: 35482xxxxxxxxxx Product Code: 0558166 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 3548xxxxxxxxxxx Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF PM write log: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) Product: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Using cached productData[0BF000192ABE00587178C7DA802B9CA6787B708E] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 1.141 s Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello xx.xxx.xx.xx SUPERDONGLE get challenge failed ! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 1.125 s when im writing full pm the most sectors failed, too. thanks for help. |
pls do it step by step MXKEY>SERVES>IMEI&SECURTY>IMEI REBUILD >REPAIR SD GO TO PM LOAD PM THEN CLICK SUPER SD AUTH AND WRIT PM FULL FACTORY |
still the same error canīt write pm. log: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) Product: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Using cached productData[0BF000192ABE00587178C7DA802B9CA6787B708E] ... Calculating SUPERDONGLE using security server ... Completed in 3.515 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-320_354xxxxxxxxxxxx_SIMSD.RPL" Updating SUPERDONGLE_KEY ...OK Updating SIMLOCK...OK ---- Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8009(15-04-2010), 1.0.0.12756(15-04-2010) Product: V 06wk41v64.20 01-10-09 RM-320 (c) Nokia Using cached productData[0BF000192ABE00587178C7DA802B9CA6787B708E] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 27 (4 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Completed in 1.203 s with different pm files. |
server probleme tray later |
