02-17-2010, 06:15 | #1 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Philippines
Member: 230087 Status: Offline Thanks Meter: 373 | MX-Key Team Please CHECK THIS Quote:
please check if its bug..... TIA. | |
02-17-2010, 11:10 | #4 (permalink) | |
Member: 230087 Status: Offline Thanks Meter: 373 | i am using the latest update............................................ Quote:
02-17-2010, 12:05 | #5 (permalink) | |
Member: 230087 Status: Offline Thanks Meter: 373 | Another one.............................. Quote:
02-17-2010, 12:43 | #9 (permalink) |
Freak Poster Join Date: Jun 2008 Location: algeria
Member: 793926 Status: Offline Thanks Meter: 67 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...Processing file: rm72_73_11003.880 as MCU [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB Supported Ids: 1052, 2051 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0035 [Samsung K5E5657ACK,256 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_essr.fia [TIKU EIJA SSR] version: 4.76.0 revision: 0.7 size: 0x9868 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...flashing terminated ! Flashing terminated with error(s) in 54.266 s RX Buffer: 0200000000D172 ............I have seam problem..... |
Mx-key team please check it | syed tuqeer | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-04-2010 19:14 |
MX Key Team please fix this Bug first | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-14-2010 12:39 |
Mx key team plz fix this problem | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-20-2010 17:24 |
All mx-key team plz fix this bug fast | el7areef | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 12-01-2009 16:13 |
mx key team help om this error.. | stacey-ann | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 11-03-2009 08:35 |
