Old 01-07-2012, 18:55   #1 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
MXKEY / MXBOX v3.5 revision 1.7 Public Discussion Thread
BUY ORIGINAL XTC CLIP PLUS
with 6 FLEX CABLES
SPECIAL PRICES IN USD
FREE SHIPPING
Nokia Tool
added:
- SL3 RSA Signature verify on "Read Hash", sha readed by MX now is 100% valid
- Disk usage info on fire.exe
improvements:
- file version indentification for installed data package
- phone images definitions in now synched with fire tool
- pinout images updated
bugfix:
- rapido usb bootstrap causing BSOD
- xgold not booting
- [sl3bf], oclHashcat 00.08 speed not shown
hti drivers updated
updated sl3u to version 1.7
- added: Master sp code verification on calculate cod
- improved: online logger function
updated sl3bf to version 3.6
- added: Master sp code verification after bf task finished
- bugfix: oclHashcat-lite-0.08 with "--outfile-format=1" problem
180 Download links:
15 links for Download mobileEx_setup_v3.5_rev1.7(20120107).exe
BR,
Manole
The Following 231 Users Say Thank You to MANOLE For This Useful Post:
Old 01-07-2012, 19:04   #2 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
If xgold not booting fixed thats good move..................
The Following 4 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 01-07-2012, 19:05   #3 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 760
Arrow
Very fast update...............Catch me if you can......................
The Following 10 Users Say Thank You to .::Gsm-Play::. For This Useful Post:
Old 01-07-2012, 19:29   #4 (permalink)
Registered User
Member: 1115410
Sonork: 100.1608126
Thanks Meter: 27
Thanks but em waiting For XGold Unlockin......
Plz Manole do some thing on dis plateform...
The Following 5 Users Say Thank You to mkw.imran For This Useful Post:
Old 01-07-2012, 19:33   #5 (permalink)
Registered User
Member: 307373
Sonork: paypal.me/div859
Thanks Meter: 590
This update works with green MX box
The Following 3 Users Say Thank You to div_859 For This Useful Post:
Old 01-07-2012, 20:00   #6 (permalink)
Registered User
Member: 1185007
Thanks Meter: 25
Nice Update Mx Team
thanks good update...
The Following 3 Users Say Thank You to GsmSoni For This Useful Post:
Old 01-07-2012, 20:24   #7 (permalink)
Member: 666861
Thanks Meter: 19
Wrong code given by bf is fixed or not?
The Following User Says Thank You to keeran For This Useful Post:
Old 01-07-2012, 20:24   #8 (permalink)
Member: 773102
Thanks Meter: 24
this log is other mx key whit mobilex 3.5 rev 1.5
flashing 5530 usb whitout problems , only problems whit 3.5 rev 1.6 3.5 rev 1.7 manole your soft have bug
MXKEY [FT SCR2000 0], SN: C08315D0
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Processing MCU file: RM-504_32.0.007_prd.core.C00
[BB5,XSR 1.5] size: 102.93 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 194568FD
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1BE00104B98700524A04F1FA5109B423A0D8C3E7
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
S***ested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS HASH: F2B05364E563A348608C1C3C9E54FE42AAAA1ACF
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: F2B05364 [RAP Certificate 168 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 54.547 s
Processing PPM file: RM-504_32.0.007_prd.rofs2.V16
[BB5,XSR 1.5] size: 21.91 MB
Erase size: 33 MB
CMT FLASH,MuxOneNAND area [07260000-0935FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 24.672 s
Processing PPM file: RM-504_32.0.007.211.06_prd.rofs3.fpsx
[BB5,XSR 1.5] size: 10.78 MB
Erase size: 11 MB
CMT FLASH,MuxOneNAND area [09360000-09E5FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 12.594 s
Processing CNT file: RM504_32.0.007_001_U211.uda.fpsx
[BB5,XSR 1.5] size: 7.75 MB
Erase size: 88.75 MB
CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF]
Programming completed in 9.829 s
Total time for flashing process(boot+erase+write) was 2 min 52.110 s
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 5530 XpressMusic USB Phonet, PORT_ID: D817CF
Verifying communication to device OK.
Phone type: RM-504 (Nokia 5530 XpressMusic)
SW version: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia
Imei plain: 35825303994960-0
Product code: 0590859
Battery voltage: 3530 mV, current: 258 mA
ApeCoreSw: V 32.0.007
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358253039949600
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 3340201549764300
PROFILE_BITS: 1000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=334020 [Mexico-Telcel ]
BLOCK2: 1=CLOSED(MCCMNC), DATA=334020 [Mexico-Telcel ]
[IMG][/IMG]
http://imageshack.us/photo/my-images...rev15done.jpg/
http://imageshack.us/photo/my-images...v17failed.jpg/
The Following 5 Users Say Thank You to christiam For This Useful Post:
Old 01-07-2012, 20:28   #9 (permalink)
Member: 1515380
Sonork: Ano yung sonork id?
Thanks Meter: 22
very nice update
i hope this update perfectly working on reading sha files.
Old 01-07-2012, 20:29   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Originally Posted by nass08 View Post
very nice update
yes, it's have RSA verified now
The Following 4 Users Say Thank You to gbluez For This Useful Post:
Old 01-07-2012, 20:42   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Partitioning....
CMT ADA block sent
CMT KEYS block sent
Erase size: 33 MB
Erase size: 11 MB
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
[IMG][/IMG]
ImageShack® - Online Photo and Video Hosting
no such bugs,
please check your own side
Old 01-07-2012, 21:33   #12 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Yes, working on both, HTI Plus (mxbox orange) and HTI (mxbox green).
I do not know why you ask this again, I made my post very clear: http://forum.gsmhosting.com/vbb/f550...dwide-1403332/
Originally Posted by MANOLE View Post
What are the new features for
HTI Plus (MXBOX ORANGE):
1. Speed for HTI PLUS (MXBOX ORANGE) is increase
with 180% comparing to HTI (MXBOX Green)
2. USB BIG connector, used by most of the boxes in market
(as was requested by many endusers)
3. Protection against Phone short-cut was added in hardware
4. Support for XTC Prog cable and software was added.
More details about this can be found in here:
http://forum.gsmhosting.com/vbb/f550...range-1403018/
5. HTI Plus (MXBOX ORANGE) comes full activated with
CDMA software, 100 CDMA credits included.
The rest of features are same like HTI (MXBOX Green).
To be clear about HTI Plus (MXBOX ORANGE) and
HTI (MXBOX Green) updates.
We will support both interfaces in all future updates.
MXBOX Green will continue to be sold by resellers and by our team.
The enduser prices are changed and listed in this threads:
http://forum.gsmhosting.com/vbb/f550...dwide-1372819/
BR,
Manole
The Following 29 Users Say Thank You to MANOLE For This Useful Post:
Old 01-07-2012, 21:50   #13 (permalink)
Member: 1381208
Thanks Meter: 13
The Following 3 Users Say Thank You to islam soloma For This Useful Post:
Old 01-07-2012, 21:51   #14 (permalink)
Member: 19271
Thanks Meter: 17
Still the same bug ;-)
Sorry, but still have the same problem after the BUS Check:
"MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C080AXXX
Using device: HTI, FW ver: 00.50, SN: 00001XXX
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
ERROR: Packet Error(0xAA), code 0xC0000001
ERROR: Packet Error(0xAA), code 0xC0000002
Error details:
Bad contact, TX line remains low !
VCC_PH BSI TX RX RX2 CLK
1 0 0 1 1 0
ERROR: bootstrap failed!"
BCP69 replaced, phone cable OK (working with UFS), USB cable with dual-power (from portable HDD), file synchronized, last box firmware... Any idea?
The Following 2 Users Say Thank You to greg777 For This Useful Post:
Old 01-07-2012, 21:53   #15 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
verry nice move sir manole
thanks for update
The Following 4 Users Say Thank You to ernie78™ For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.32211 seconds with 10 queries
