11-02-2011, 11:53 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 507861 Status: Offline Thanks Meter: 69 | n96 cant repair sd pls help.... logs: MXKEY [FT SCR2000 0], SN: ******** Using device: HTI, FW ver: 00.24, SN: ******** Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: DE51484FBB431933D6A3C37DFD879A765F24DF9D ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 18A00114B0710052FE8E183F3DA4EB8ADDC4CE49 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE TransmissionMode: DDR&TX2 SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 Storage0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: FLASH,NAND, asic:APE Suggested algorithm: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Original Imei: 35486302493608 Original Product code: 0567373 Bluetooth ID: 002404793F15 WLAN ID: 0024047A2975 SIMLOCK PA identifier: [0] PA_SL2 Phone type: RM-247 (Nokia N96-1) SW version: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia Imei plain: 35486302493608-3 Product code: 0567373 Battery voltage: 4520 mV, current: 171 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! logs of repairing sd...... MXKEY [FT SCR2000 0], SN: ******** Using device: HTI, FW ver: 00.24, SN: ******** Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011) Phone type: RM-247 (Nokia N96-1) SW version: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia ApeCoreSw: 12.043 SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW ------- stop here thanks Last edited by ELOY1024; 11-02-2011 at 11:56. Reason: a |
11-02-2011, 21:48 | #2 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1605139 Status: Offline Thanks Meter: 6 | Once I had a similar problem. What I did was downgrade the phone, go to Simlock Service/Imei & Security/Simlock/PA_SL2/Make Simlock RPL/Repair Simlock, then repair super-dongle and finally flash last version. Can you flash the phone ok? |
The Following User Says Thank You to harjeev For This Useful Post: |
11-03-2011, 00:33 | #3 (permalink) |
Member: 507861 Status: Offline Thanks Meter: 69 | i also try to repair simlock but same result as sd repair.. nothing happens and i also flash high and low version to phone ... in flashing no problem all is ok. but i cant repair sd and simlock ... thanks |
11-03-2011, 01:38 | #6 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, try to update your mobileex first. click here. do sync after. this problem is not for all rapido, just some rapido. if still the same error, you have to wait the update fix. i am sorry bro. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
11-03-2011, 12:29 | #9 (permalink) | |
Member: 507861 Status: Offline Thanks Meter: 69 | Quote:
i use hti box and v3.5 rev1.2... standalone enable sir..not server base coz 3.5 rev1.2 is outdated in server base Last edited by ELOY1024; 11-03-2011 at 12:33. Reason: a | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
