03-03-2010, 13:58 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Pakistan Age: 36
Member: 158181 Status: Offline Thanks Meter: 113 | n96 phone startup failed contact retailer i have 2 n96 phones in that problem. here is 1st log Version Info: MCU SW version: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia HW version: 1050 RFIC version: 17141715 Tahvo version: 16 APE HW version: 22 Product Info: Product code: MRE210820 Module code: 0543713 Long production SN: 0 Serial Numbers: IMEI plain: 359320024861329 IMEI spare to net: 3A 95 23 00 42 68 31 02 IMEI SV to net: 33 95 23 00 42 68 31 02 F6 Other Info: Model : Nokia N96-1 (Classic Phone) CS type : GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA VIII BSI: 6.7 KOhm Imei net: 359320024861329 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF plz complete guide that how i repair that phone |
03-03-2010, 14:21 | #2 (permalink) |
Insane Poster Join Date: Sep 2007 Location: istanbul
Member: 579426 Status: Offline Thanks Meter: 4 | i have same prob with 2 phone n85 & n96 here is n85 Code: Phone Type: RM-333 (Nokia N85) SW Version: V ICPR72_08w44.1 10-11-08 RM-333 (c) Nokia Imei plain: 35637602553405-2 Product Code: 0575404 ApeCoreSw: 11.047 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2008-12-04T09:59:34+00:00 SW Version: 11.047 Variant Version: 001 ProductProfile: RM333_0575404_11.047_001.spr Simlock: simlock_3gstandard_bb5.bin Imei net: 356376025534052 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF and here is n96 Code: Phone Type: RM-247 (Nokia N96-1) SW Version: V ICPR72_09w13.2 19-05-09 RM-247 (c) Nokia Imei plain: 35932002460070-1 Product Code: 0543722 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-06-18T13:39:11+00:00 SW Version: 30.033 Variant Version: 001 ProductProfile: RM333_0575404_11.047_001.spr Simlock: simlock_3gstandard_bb5.bin Imei net: 359320024600701 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF anybody can enplane me how to repair this two phnes ? |
03-03-2010, 14:30 | #3 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
after seeing ur phone logs both log are okay ... but regarding ur problem .. first upgrade the firmware of ur phone ... if then it is not solve then it may be due to hardware... in hardware try to change avilma ic.... post result..... | |
The Following User Says Thank You to digitized For This Useful Post: |
03-03-2010, 14:37 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: nothing
Member: 494167 Status: Offline Thanks Meter: 292 | Quote:
The Following User Says Thank You to software zone For This Useful Post: |
10-09-2010, 12:14 | #11 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1279141 Status: Offline Thanks Meter: 0 | need help please, Flashing finalization failed. Do you like to retry the finalizing? HRESULT 0x8421001c (-2078212068) Firmware: Cannot verify communication to phone after flashing. Make sure that phone booted up correctly and retry. |
10-09-2010, 12:50 | #12 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
BR | |
N96.. Phone Startup fail...contact retailer | Waseem-y | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 01-09-2010 09:55 |
Repair....phone Startup Failed Contact Retailer | krusty.spritz | Nokia Base Band 5 ( BB-5 ) | 0 | 05-16-2007 18:41 |
Nokia 6600 Phone Startup Failed Contact Retailer | ktelecom | WD2 & APE (Symbian Phones) | 16 | 05-01-2007 11:55 |
n70 phone startup fail contact retailer | fast_alex1123 | Nokia Base Band 5 ( BB-5 ) | 5 | 03-08-2007 21:21 |
