04-20-2010, 17:41 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Saudi Arabia
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | n96 startup fail.....? - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2009-06-18T14:15:26+00:00 SW Version: 30.033 Variant Version: 001 ProductProfile: Simlock: simlock_3gstandard_bb5.bin Imei net: 354863025125066 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF i do sd rpr &cert recovr but still the pro hoe can fix............? |
04-20-2010, 17:44 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | Mxkey>serves>imei&securty>imei rebuild >repair sd go to pm load pm then click super sd auth and writ pm full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
04-20-2010, 17:54 | #3 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model I tested 100%. |
04-20-2010, 18:15 | #5 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | sir i do it full but sam problm.....................? This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! TimeStamp: 2009-06-18T14:15:26+00:00 SW Version: 30.033 Variant Version: 001 ProductProfile: Simlock: simlock_3gstandard_bb5.bin Imei net: 354863025125066 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-20-2010, 18:17 | #6 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: Poland
Member: 372482 Status: Offline Thanks Meter: 93 | Quote:
04-20-2010, 18:55 | #8 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | Imei net: 354863025125066 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF APE Data : SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x] ASIC MODE ID: 00 PUBLIC ID: 3D9AA8F389D4106EB0F44536B1FFD203CF1CB72D ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35 ROM ID: 137A9A3B33259D2C RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 2080000A5E720052A71B9ABE7F31079C22EA9508 ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE ALG [35]: N8815 ALG STNFMS Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78 Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3 APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE Reading RAP NPC (0x1B8 bytes) Original Product Code: 0567376 Reading RAP VARIANT (0x0 bytes) VARIANT empty ! varian emty .....how can fix............? |
04-20-2010, 19:35 | #13 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | 4shared.com - online file sharing and storage - download BB5_35486302512506_BACK.rpl her is antr........... |
04-20-2010, 19:47 | #14 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | bro, rpl ok try this backup rpl rest npc go to pm click erase pm writ backup rpl repair sd (you will get rpl to repair sim & sd) go to pm >load this pm 4shared.com - online file sharing and storage - download RM-247_.pm click sd auth and writ pm fullfactory then post result |
startup logo on 8890 | adwiser | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 12-31-2000 00:30 |
startup logo on 8890 | adwiser | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-26-2000 02:55 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
Startup Logo to be used as Operator Logo | Beachbum | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-09-1999 18:43 |
