Old 02-25-2011, 05:38   #1 (permalink)
Maninder_111's Avatar
Member: 687144
Sonork: 1614780
Thanks Meter: 228
what is this problm (ANSWERED)
sir i have a N95-8GB restart fault , but when i do flash with hwk , flashing ok with hwk , but when i flash with mxkey show it problm
Version from phone: 06wk41v64.20
Version from file: 35.0.001
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9100(23-12-2010), 1.0.0.15151(24-12-2010)
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: 353252D6F7D7F0DF4DDC4C4BCE788E17C5DA3EC2
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1200011770C80158268D95A36CB0EA8255369BD1
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Flash ID not supported for this loader (RAPIDOv11_XSR15_alg.fg)
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.18.2 revision: 2.0 size: 0x697DA
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
loader not responding (0200000000F172)
Flashing terminated with error(s) in 25.687 s
RX Buffer: FFFFD372
Old 02-25-2011, 05:53   #2 (permalink)
abidottupara35's Avatar
Member: 1178222
Sonork: 100.1602620
Thanks Meter: 467
bro
abid
The Following User Says Thank You to abidottupara35 For This Useful Post:
Old 02-25-2011, 06:18   #3 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
thnx
but now show this problm plz solve this
Old 02-25-2011, 06:19   #4 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
Invalid imei plain, RPL backup skipped.
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
TransmissionMode: DDR&TX2
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported Ids: 24200703, 24200704, 24200705, 24200706
Flashing terminated with error(s) in 59.891 s
RX Buffer: F372
Old 05-02-2011, 08:00   #5 (permalink)
Member: 85995
Thanks Meter: 9
I have the same problem any solution ?
Old 05-02-2011, 08:03   #6 (permalink)
gsm_links's Avatar
Member: 561947
Sonork: 100.1580399
Thanks Meter: 948
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
RX Buffer: FFFFD372
dear maninder
did u use mx box with mx key. mxbox (powered by mx key team).
Wbr
s n hasan
Old 05-02-2011, 19:22   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
post your own logs please?
Old 05-05-2011, 05:49   #8 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
my n95 8gb is ok now so ............ thnx to all helper
Old 05-05-2011, 06:03   #9 (permalink)
Member: 1468508
Thanks Meter: 159
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 19100201FE9A8E56E59DE74FEB3A1A2CEFEB6F4C
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS is blank/erased.
Processing MCU file: rm561__09.97.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00040000-000BFFFF]
CMT NOR area [000C0000-0013FFFF]
CMT NOR area [00140000-0137FFFF]
CMT NOR area [01380000-0151FFFF]
erased in 5.906 s
Flash programming ...
Error while programming [00] at 0x00040000, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: F3 72
Old 05-06-2011, 13:11   #10 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 21 MB
erased in 5.906 s
Flash with ufs ya ATF ..
Old 05-06-2011, 13:11   #11 (permalink)
Member: 687144
Sonork: 1614780
Thanks Meter: 228
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 21 MB
erased in 5.906 s
Flash with ufs ya ATF .... & give me regult
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Page generated in 0.31539 seconds with 9 queries
