02-15-2013, 14:01 | #1 (permalink) |
Insane Poster Join Date: Nov 2009
Member: 1154494 Status: Offline Thanks Meter: 3 | Need Help Asha 200 Here is the bus check Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: Using device: USB Phonet and HTI, FW ver: 00.50, SN: Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdnsuc, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 2CA36857 Verifying communication to device OK. Phone type: RM-761 (Nokia 200) SW version: V 11.81 20-08-12 RM-761 (c) Nokia Imei plain: Product code: 059K928 Detected as DCT4 phone, check Generation selection ! Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 06150123008027, ver: MMC password: SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Code: Phone Type: RM-761 SW version: V 11.81 20-08-12 RM-761 (c) Nokia ID Test name Startup Result 33 SIM_LOCK N passed 93 SECURITY N passed 90 PWR_KEY N passed 2 CURRENT_CONS N passed 43 LCD N passed 44 LPRF_AUDIO_LINES N passed 21 LPRF_IF N passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 101 BTEMP N passed 118 RF_ANTENNA N passed 112 CDSP_PA_TX_POWER N passed 227 SLEEP_CLOCK_FREQ N passed 52 KEYB_LINE N passed 10 ADC_IF N passed 50 MEMORY_CARD_IF N !no signal 53 SIM_MULTIPLEXER_IF N passed 17 RF_PLL N passed 45 FEM_CURRENT N !no signal 47 SECURITY_FUSE N passed 114 IO_EXPANDER_IF N passed => HTI On USB, what this box can do? Super SD Auth and Repair SD not working, anybody can give some idea what is going on? |
