01-14-2011, 11:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: SKY Age: 78
Member: 910577 Status: Offline Thanks Meter: 242 | Need help for mxkey team plsss can anyone tell me how to get the hsahs file from mxkey pls bez i dont have super pc and i want to get the hsahs file if anyone know pls pls pls let meknows thanks mxkey is the best ali_7867 |
01-14-2011, 12:43 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | 1. Identify phones with "Scan Phone" (as usuall) to see if it is SL3 phone. 2. Go to "IMEI & Security" tab and select"Online Logger" it is sl3 100 credit logger.if you have. 3. Click "Login", and if your card is activated SL3 Unlock panel will be visible. 4. Click "Read Phones IDs" to prepare the data which is needed for bruteforce task (this will also identify is phone is supported or not), new file {IMEI}.sha will be created at folder "{MOBILEEX}\data\SL3\" 5. Click "Start Bruteforcer" and select {IMEI}.sha file. Random Salt is checked by default which mean the task will using random data to make bruteforce instead of using normal sequence. 6. After some time and the bruteforcer task completed, it will create file {IMEI}.cod to the same folder as {IMEI}.sha file 7. Then go back to main exe, and do "Calculate Codes" to get the unlock codes, unlock code will be saved as {IMEI}_SP_CODES.txt. Tick "Send to the phone" to directly send the codes to the phone. 8. Task is done and the phone was unlocked, enjoy ! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
