03-24-2010, 10:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: New Delhi
Member: 1005011 Status: Offline Thanks Meter: 25 | 2300 imei plain ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2227 [Samsung K8S3215ETD,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0041540C:2984DA60 ASIC type: 2 UEM Imei: F553600C888B41 Invalid uem checksum, UEM might be damaged ! Connecting to server ...OK, Login ... Hello C*******, you have *** credits left. Invalid IMEI Data, No RPL backup will be made for this phone. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2227 [Samsung K8S3215ETD,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0041540C:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RM-4 SW Version: V 8.11 19-06-06 RM-4 (c) NMP 2300 Imei plain: ??????????????-? Product Code: 0513310 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Indonesia,Filipino Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 9A6160268862BDFA PROFILE_BITS: 389D11C6578D199F BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
The Following User Says Thank You to laksh007 For This Useful Post: |
04-16-2010, 15:22 | #4 (permalink) | |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | Quote:
5130 problem IMEI plain is invalid | shreedid123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 25 | 03-25-2010 11:43 |
IMEI plain 12345678910[OLD POST] | Hitec Wireless | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 17 | 03-01-2010 09:50 |
5610 IMEI Plain Invalid | shreedid123 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-23-2010 11:10 |
1650 flash done, IMEI plain : ??????????????? | bui_theanh | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-24-2008 09:33 |
9500 imei plain ???????????? | lie_james | WD2 & APE (Symbian Phones) | 11 | 09-24-2007 22:47 |
