03-01-2012, 09:37 | #1 (permalink) |
Insane Poster Join Date: Nov 2009
Member: 1154494 Status: Offline Thanks Meter: 3 | Need help to PPM Auth for Nokia 5220 Code: Phone type: RM-411 (Nokia 5220 XpressMusic) SW version: V 07.23 17-07-09 RM-411 (c) Nokia Imei plain: Battery voltage: 4429 mV, current: 87 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Code: Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Retrying ... SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Retrying ... SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Retrying ... SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.2 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...Connection timed out Repair SD done Same SECURITY_TEST failed! please let me know where i made mistake. |
03-01-2012, 09:48 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
03-01-2012, 10:07 | #4 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | 1. back up rpl (just in case) 2. dont tick load rfbb from server 3. click repair sd, if pop up menu ask u to write rfbb data, click NO 4. load pm file for 5220 (full or 1 & 309 is okay) 5. write it 6. repair dcc file << last thing i would do in fact, u can do what u want with the phone after back up rpl, try erase flash, etc if not success, so have fun bro... br |
The Following User Says Thank You to specta For This Useful Post: |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
