03-04-2013, 19:37 | #1 (permalink) |
Freak Poster Join Date: Dec 2011 Location: BIRBHUM,W.B,INDIA
Member: 1707667 Status: Offline Sonork: 100.1611124 Thanks Meter: 60 | Need help to recover nokia 5130 when i try to power on with bettary it show "contact service, but when i set normal mode from software it go to nor mal mode and all ok. I can not understand what is the problem. Please help mo to recover this hand set. |
03-05-2013, 06:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. It's Hardware, Try to remove Camera & check with Battery whether it's ON normally, If ON normally then clean Camera & Contacts with Connector or replace Camera to confirm about, If same as before after removing Camera, means possibility of AVILMA IC defected (Ear Data Loop failed in Selftest), So Clean PCB & follow above must solve it. BR, ZUBER |
