need urgent help error flashing 3120c phone is dead while reading message try flash with mx key log Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm364__09.41.mcusw as MCU [BB5,BB5 ALGORITHM] size: 20.61 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 193352DF RAP SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 12A00218A9C57C56926F34F5F693A8A5850BD320 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x49780 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x57D40 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: EDD735B [ADL] Verifying communication to device OK. Erase size: 21.87 MB CMT NOR area [00000000-0001FFFF] erased in 0.516 s CMT NOR area [00040000-000BFFFF] erased in 1.781 s CMT NOR area [000C0000-0013FFFF] erased in 0.094 s CMT NOR area [01480000-015FFFFF] erased in 5.171 s CMT NOR area [00140000-0147FFFF] erased in 56.032 s Flash programming ... CMT PAPUBKEYS: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79 (RAP Certificate 114 v1) written. Programming completed in 1 min 43.015 s Processing file: rm364__09.41.ppm_w as PPM [BB5,BB5 ALGORITHM] size: 5.90 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.75 MB CMT NOR area [01600000-01CBFFFF] erased in 18.015 s Flash programming ... Programming completed in 30.015 s Processing file: rm364__09.41_ISM_010.image_w_in_graphite as CNT [BB5,BB5 ALGORITHM] page size: 128 K size: 8.50 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 34.87 MB CMT NOR area [01FC0000-03F9FFFF] erasing ... Error while erasing 02 area 0x01FC0000-0x03F9FFFF, Result: 00000000000000 , 0 Flashing terminated with error(s) in 4 min 1.750 s pls help regards riaz |
u use mx-key? some time mx-key make this problem. so u flash next time & connect ufc cable properly or good others flash cable. i think u works done. |
thank you have already tried with different cables and even tried flashing with ufs yet same regards riaz |
flash with UsB and post result bro.................. BR, |
pls check the log posted is of usb flashing regards riaz |
