03-22-2010, 16:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: maldives
Member: 389862 Status: Offline Sonork: guy_askali Thanks Meter: 54 | NEW UPDATE FIXMXKEY v3.3 revision 1.7 - Public discussion thread MXKEY v3.3 revision Direct link for download MXKEY V3.3 revision 1.7: RapidShare: 1-CLICK Web hosting - Easy Filehosting MAIN - Added, support for JAF BOX firmware 01.B4 - Fixed, Runtime Error when multiple instance loaded - Small ui changes, added module icon in menu. NK - Added, BB5 Warranty Unlock function !!! FIRST IN THE WORLD !!! Warranty Unlock will read unlock codes without direct write to the phone. Thus will make sure that the phone`s warranty is not void, a window will display the phone information, unlock codes and intruction to enter the codes as well. ~ a template file as html doc located to "\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\codtemplate.htm". ~ you might edit this template as you want as long as keep the variables "%model%","%imei%","%provider%","%codes%" and %codes7%. - Added, CMLA_KEY and SUPERDONGLE_KEY RPL backup - Added, New Loader/Protocol support for JAF BOX (RAPIDO,RAPU based phones) - Added, Multi-ReLock support As requested by some user, now possible to LOCK the phone to multi-providers. As the providers settings are maybe outdated, you might need to edit the providers list: ini file setting located to "\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\providers.ini". the format is [8DIGIT MCC+MNC]=[PROVIDER_NAME]|COUNTRY eg: 23430000=Virgin|United Kingdom - Added, Method1 (old) and Method2 (new) option for DCT4PLUS SIMLOCK Patch (will be used in future DCT4PLUS unlock updates) ~ Fast Flash routine will collect the list image files and process with one boot. NK - Previous changes(rev 1.6 Partial-Update) - Added BB5 RAP3GV4 USB Flashing(eg. Nokia X3-00,X6-00) - Added Dead Usb option for normal usb flashing (This will force software to use dead usb protocol without need to reconnect the Nokia USB ROM connection) - Many Minor bug fixes BB - Previous changes(rev 1.6 Partial-Update) - Added, manual checkbox to allow input IMEI+MEP manually(in case of usb connection problem). - Added, Engineering Screen Unlock code calc. |
The Following 4 Users Say Thank You to guy_askali For This Useful Post: |
03-22-2010, 17:18 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: MXBOX THUNDER
Member: 780644 Status: Offline Sonork: 100.88888 Thanks Meter: 131,943 | You no need open new thread. ONLY here is public discussion about MXKEY v3.3 revision 1.7 http://forum.gsmhosting.com/vbb/f550...thread-955259/ BR, Manole |
The Following 2 Users Say Thank You to MANOLE For This Useful Post: |
MXKEY v3.3 revision 1.7 - Public discussion thread | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 491 | 08-19-2010 00:44 |
v3.3 revision 1.3,Public-Release | gsm junction | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-11-2010 11:13 |
MX-KEY v3.3 revision 1.3 public discussion thread | MANOLE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 368 | 02-07-2010 23:10 |
MX-KEY v3.3 revision 1.3 BUGS public discussion thread in DCT4 | hendiek | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 01-27-2010 08:35 |
