Old 01-25-2010, 08:57   #1 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
5220 rm411 recovert CERT failed, Result: 06C0000000117200
Updating CMT HWC ...failed, Result: 06C0000000117200 what is problem n how to solved?
here is log
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 2290001907190354733F29136ECD81CB574E8787
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
Reading RAP NPC (0x168 bytes)
Begin Certificate Request ...
Connecting to server ...OK, Login ...
Query done with status: OK
Updating PRODUCTCODE (0564177)... OK
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Certificate programmed successfully !
br;
Old 01-25-2010, 09:01   #2 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
Show me your Logs.
What is your phone problem ,you forgot to mention.
Old 01-25-2010, 09:13   #3 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
Originally Posted by Umair Rashid View Post
Show me your Logs.
ok,here is
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11813, Date: 21-01-2010
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Original Imei: 35366201593445
Original Product code: 0564177
Bluetooth ID: 0021ABED5251
Phone Type: RM-411 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-411 (c) Nokia
Imei plain: 35366201593445-8
Product Code: 0564177
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
TimeStamp: 2009-04-14T13:05:57Z
SW Version: 06.51
Variant Version: 007
ProductProfile: RM411_0564177_06.51_007.spr
Simlock: 0564177_simlock.bin
Imei net: 353662015934458
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
br;
Old 01-25-2010, 09:24   #4 (permalink)
Member: 739618
Thanks Meter: 16
Your phone SL3 bro
and SD repair can't be solved with any tool. kapreh loen peuget SD repair SL3 beh
SIMLOCK_TEST passed
br
memedyosep
Old 01-25-2010, 09:29   #5 (permalink)
Member: 421117
Thanks Meter: 2,522
Originally Posted by kirta View Post
ok,here is
SIMLOCK_TEST passed
SW Version: 06.51
Counter: 0/3, 0/10
br;
YOur phone's Superdongle key is damaged.
Can't possible to repair with Mx-key.
Use other tools and Expensive credits.
Originally Posted by memedyosep View Post
Your phone SL3 bro
memedyosep
It's not SL3 phone.
It's BB5 RAp3
Old 01-25-2010, 09:29   #6 (permalink)
Member: 739618
Thanks Meter: 16
how to know your SL?
Service-IMEI& security-simlock- identify
sekian pelajaran dari
memedyosef
napeng baye boh drien ot...
bek gadoh baye pulot
Old 01-25-2010, 11:10   #7 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
Your phone SL3 bro
SIMLOCK_TEST passed
br
memedyosep
memedyosef
stupid solution.........
Old 01-25-2010, 11:18   #8 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
ok!!!what function recover CERT the lates update mx key Can you explain it?
br;
Old 01-25-2010, 12:48   #9 (permalink)
Member: 938399
br;
recover CERT not to repair SD bro..
just wait and see in the next update
gadoh mita free kayu blo UB bak toke
br
Old 01-25-2010, 12:50   #10 (permalink)
Member: 421117
Thanks Meter: 2,522
br;
It rebuilds the following Data of your CERT,
1.HWC
2.CCC
3.Variant
etc
Old 01-25-2010, 15:54   #11 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
br
you do not know anything about your key mx yesterday afternoon only son you better listen and see what you consider to senior experience will be the future without having to provide solutions
br;
Old 01-25-2010, 15:58   #12 (permalink)
kirta's Avatar
Member: 898963
Thanks Meter: 69
1.HWC
2.CCC
3.Variant
etc
thank's nice info brother.........
br;
Old 01-30-2010, 08:20   #13 (permalink)
Member: 490091
Thanks Meter: 2
Imei: 35366201792552
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1E80000EB469575079A0C0A89AFCAF7EDD134D4C
ASIC MODE ID: 00
NPC verified Ok.
Erasing CMT NPC ... OK
Imei plain: 35366201792552-0
Product Code: 0563611
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353662017925520
Counter: 0/3, 0/10
Old 01-30-2010, 08:30   #14 (permalink)
Member: 490091
Thanks Meter: 2
SIMLOCK_TEST passed
plis help
Old 01-30-2010, 19:36   #15 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
SIMLOCK_TEST passed
plis help
your phone already fix superdongle with other tool ?
can u do sx-4 on mxkey server ?
if can continues with write pm ,except [308] area
br,
The Following User Says Thank You to Andra For This Useful Post:
5220 rm411 pm modify anam120 Nokia Base Band 5 ( BB-5 ) 3 07-11-2013 10:36
CMT VARIANT ...failed, Result: 0000000000000000 NAVEED74 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 06-08-2010 09:39
Unlock 5220 RM411 v4.60 Tequilas Cyclonebox 2 10-28-2009 23:47
5220 rm411 abrahem Nokia Base Band 5 ( BB-5 ) 0 05-08-2009 22:54
5220 rm411 arnoldobalobao Universalbox 1 12-03-2008 12:31
Page generated in 0.26167 seconds with 9 queries
