06-21-2010, 11:04 | #1 (permalink) |
Registered User Join Date: Jan 2008 Location: Where never ends.
Member: 669673 Status: Offline Thanks Meter: 301 | No RAP Flash Chip Detected......... Solution. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2F000217CA268C56945F1467EFFB9E226348ADF1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Original Imei: 00000000000000 Original Product code: I need Solution any one help me. Thanks to all GSM members. Flash Tab Logs - Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) Processing file: rm217__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.50 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2F000217CA268C56945F1467EFFB9E226348ADF1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Storing certificate [NPC, VARIANT, R&D] ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.406 s CMT NOR area [000006C0-0001FFFF] erased in 0.156 s CMT NOR area [00020000-0007FFFF] erased in 1.141 s CMT NOR area [00080000-000DFFFF] erased in 0.484 s CMT NOR area [00100000-001FFFFF] erased in 0.969 s CMT NOR area [00200000-0031FFFF] erased in 3.188 s CMT NOR area [00320000-0105FFFF] erased in 36.281 s CMT NOR area [01060000-01067FFF] erased in 0.437 s CMT NOR area [01068000-0107FFFF] erased in 0.406 s Flash programming ... CMT PAPUBKEYS: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 (RAP Certificate 52 v1) written. Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00704400, Result: 0010 Flashing terminated with error(s) in 4 min 14.782 s RX Buffer: C7012D0103CD000010000000F172 Last edited by ravi mobile; 06-21-2010 at 11:11. |
The Following User Says Thank You to ravi mobile For This Useful Post: |
06-22-2010, 13:51 | #5 (permalink) |
Junior Member Join Date: Jan 2008
Member: 670138 Status: Offline Thanks Meter: 1 | the dongle said that the problem is in bsi pin,that means that the problem is between the cable or the bsi resistance it must be at the range of 7 kohm,second if that doesnt work you have to rehot the combo memory its the flash memory under the rapgsm the cpu,make 360 degree to 380 carefuly under the mother board and after clean it,and this two solutions works for me... good luck... |
08-01-2010, 08:48 | #7 (permalink) |
Freak Poster Join Date: Apr 2008 Location: west java
Member: 756701 Status: Offline Sonork: 100.1592286 Thanks Meter: 91 | how to slove for my problem? Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 18B0010541F26C563571C122B3AC4767C469B5D4 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 ID 32: 000200400000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 TransmissionMode: DDR&TX2 No RAP Flash Chip Detected Original Imei: 3586470xxxxxxxxx Original Product code: 0537684 Bluetooth ID: 001D983A0C03 Phone Type: RM-217 (Nokia 6300) SW Version: V 07.21 05-11-08 RM-217 (c) Nokia. Imei plain: 3586470xxxxxxxx Product Code: 0537632 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358647016933158 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF just restart if during on off pressed. thanks for advance |
The Following User Says Thank You to sumatera For This Useful Post: |
08-01-2010, 10:42 | #8 (permalink) |
No Life Poster Join Date: Aug 2007 Location: nepal
Member: 564325 Status: Offline Thanks Meter: 104 | it is most probably a hardware problem related to taivo ic either rehot it or reball it good luck |
The Following 3 Users Say Thank You to Raznet For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
