12-29-2011, 17:09 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: King of Nokia Age: 47
Member: 28531 Status: Offline Thanks Meter: 90 | no read any phone Initializing HTI ... HTI initialized. Boot version: 00.07 Serial: 00005936 Receive firmware from server ... SERVER->MXKEY - BLADE Z at upd, agent version 1.2 revision 0.0 Firmware version on server: 00.50 changes: added: boot mode switch function improved: serial and flash bus communication routine added: dct4 product data calc algorithm added: broadcom sec.repair algorithm minor bug fixed. Received buff checksum verified OK. Updating HTI firmware, please WAIT ... HTI firmware update OK. » End transaction (status: 0, Successfull) Waiting HTI in application mode ...Done. synchronize files Definitions file is identical and up to date, no need an update. ok connect hti Using device: HTI Flasher Interface (WinUSB) Connection status: NUSB3XHC:NUSB3HUB:USB 2.00 Full-speed Interface: MXBOX/HTI (Powered by MXKEY) Boot ver: 00.07, Box SN: 0000XXXX FW version: 00.50 HTI Flasher Interface (WinUSB) ready. nokia tool ready NK module version: 1.24 NK applet version: 00.20 NK module ready. HTI connected as additional security service. STANDALONE MODE enabled. Please "Scan" or "BUS check" before any operation ... bus check MXKEY [FT SCR2000 0], SN: C0XXXXXX Using device: HTI, FW ver: 00.50, SN: 0000XXXX Connection status: NUSB3XHC:NUSB3HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Error flash config request! select all config flash scan can't read any phone phone work normaly hti update after problem before work hti ok but use old version problem again use versiyon mobileEx_setup_v3.5_rev1.5(20111110).exe mobileEx_setup_v3.5_rev1.6(20111213)_4.exe check update hti |
12-30-2011, 12:06 | #5 (permalink) |
Member: 28531 Status: Offline Thanks Meter: 90 | MXKEY [FT SCR2000 0], SN: C08422D2 Using device: HTI, FW ver: 00.50, SN: 00005936 Connection status: NUSB3XHC:NUSB3HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) ERROR: Packet Error(0xAA), code 0xC0000001 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! bb5 buc check erorr |
