07-13-2014, 08:41 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Nokai 210 MMC file flashing problem Here is log MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C086**** Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01006**** Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: nmwcdc, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.56 EBL version: Quantum_Bootloader_10.56_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 00EC 3012 - 23280002 [Samsung ] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Processing file: rm924__06.09.mcusw Downloading item CODE:rm924__06.09.mcusw_ebl_psi.fls, num block: 4, size: 27.50 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.344 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.360 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.547 s Erasing area 0x40280000-0x41CBFFFE ...OK Programming completed in 33.734 s Checksum verified (0xE361) Processing file: rm924__06.09.ppm_ma3 Downloading item CUSTackage_ma3.ppm_ebl_psi.fls, num block: 1, size: 3.94 MB Erasing area 0x41CC0000-0x420AFB62 ...OK Programming completed in 4.969 s Checksum verified (0x44C0) Processing file: rm924__06.09.image_ma3_059R9K5 Downloading item CUSTackage_ma3_059R9K5.image.fls, num block: 1, size: 12.38 MB Erasing area 0x42300000-0x43E1FFFE ...OK Programming completed in 15.937 s Checksum verified (0xE3A4) Total time for flashing process(boot+erase+write) was 4 min 2.204 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 355514052453322 Verifying communication to device OK. Phone type: RM-924 (Nokia 210) SW version: V 06.09 14-10-13 RM-924 (c) Nokia Imei plain: 35551405245332-2 Product code: 059R9K5 Battery voltage: 3994 mV, current: 196 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MA3 Language Pack: - not available. Camera config: 115B6002004020, ver: Imei net: 35551405******** Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
