Old 06-13-2013, 16:46   #1 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
Nokia 101 contact service any solution
nokia 101 contact service problem any solution yet see full log pls tell its hardware or software problem phone is looking fresh condition
Old 06-13-2013, 16:51   #2 (permalink)
jawedakht's Avatar
Member: 992600
Thanks Meter: 1,670
1st check lcd ways
2nd change lcd 100% tested many times
The Following User Says Thank You to jawedakht For This Useful Post:
Old 06-14-2013, 06:50   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Try to Flash it 1st, solved this by Flashing too,
If no success, then change LCD, but clean LCD Points before change for Waterlogged may also effect it.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 06-14-2013, 06:54   #4 (permalink)
samo_d1's Avatar
Member: 1483881
Sonork: 100.1612698
Thanks Meter: 93
i think in your phone lcd or lcd track fault
Old 06-14-2013, 07:45   #5 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
jist change lcd your problem solve u dont de lcd tewst faild
Old 06-14-2013, 09:20   #6 (permalink)
Member: 1908388
Thanks Meter: 24
Br not solution ..............
Old 06-14-2013, 09:29   #7 (permalink)
Asia_Phone's Avatar
Member: 1300241
Sonork: 100.1626973
Thanks Meter: 356
100% LCD line or LCD please check it!
Old 06-14-2013, 12:07   #8 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
http://www.u2ugsm.com/blog/wp-conten...-Solution..jpg
BR, TEJARAM
Old 06-15-2013, 05:12   #9 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
I agree with you !!!!!!!!!!!
Old 08-12-2013, 17:35   #10 (permalink)
Member: 1646282
Sonork: 123456
Post contact service nokia 101
sl data crupect
Old 08-27-2013, 06:26   #11 (permalink)
Member: 1357792
Sonork: 39600
just flash set will ok
Old 08-27-2013, 07:03   #12 (permalink)
cellcare sams's Avatar
Member: 1537063
Thanks Meter: 74
re flash same product code . your problem solved.
Old 01-10-2014, 00:17   #13 (permalink)
Member: 1692433
anyone can show succes to solve this problem??
Old 01-10-2014, 09:57   #14 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
You can solve this way: http://forum.gsmhosting.com/vbb/f550...3/#post9499335
It's 100% solution.
BR,
ZUBER
Old 01-14-2014, 02:17   #15 (permalink)
Member: 1692433
contact service
self tesT LCD: failed = track ways is solutions
IF self test LCD:unknownid: = try on track ways or Replace LCD
tested by me....
The Following User Says Thank You to fooadz For This Useful Post:
Page generated in 0.21642 seconds with 8 queries
