01-23-2013, 14:48 | #1 (permalink) |
Product Supporter Join Date: Feb 2010 Location: .::INDIA::.
Member: 1236722 Status: Offline Sonork: 100.1601546 Thanks Meter: 4,180 | Nokia 110 Succesfull Flash Done Via Mxkey Nokia 110 Succesfull Flash Done Via Mxkey Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C086D01B Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100352F Connection status: EHCI:HUB:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Processing file: rm827__03.04.mcusw Downloading item CODE:rm827__03.04.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.453 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.375 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.578 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 44.110 s Checksum verified (0x74A0) Processing file: rm827__03.04.ppm_mh2 Downloading item CUST:package_mh2.ppm_ebl_psi.fls, num block: 1, size: 3.14 MB Erasing area 0x41BC0000-0x41EE2456 ...OK Programming completed in 4.719 s Checksum verified (0xB239) Processing file: rm827__03.04.image_mh2_059N0J3_059P8F5_226_01 Downloading item CUST:rm827__03.04.image_mh2_059N0J3_0 , num block: 1, size: 15.13 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 21.953 s Checksum verified (0xA93E) Total time for flashing process(boot+erase+write) was 8 min 1.641 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 52B3FE9 Verifying communication to device OK. Phone type: RM-827 (Nokia 110) SW version: V 03.04 20-04-12 RM-827 (c) Nokia Imei plain: 35328705566504-2 Product code: 059P8F5 Battery voltage: 5150 mV, current: 138 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MH2 Language Pack: - not available. Camera config: NI00CS0000040C21AC67, ver: 004.032 MMC password: .2345 Imei net: 35328705566504 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Br Vikash |
The Following 4 Users Say Thank You to VC_INDIA For This Useful Post: |
01-23-2013, 15:05 | #3 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Good Job Dear. BR. Arsalan gsm2000. |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
