05-01-2010, 12:07 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | nokia 1100 flashing error i want to flash 1100 set they show this error Library version: 1.0.0.8069(22-04-2010), 1.0.0.12811(22-04-2010) Boot error: 00 DD DD DD TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Processing file: rh18_08.110 as MCU [DCT4,DCT4 ALGORITHM] size: 1.46 MB Supported Ids: 0120, 0121, 1120, 1021, 1201, 2201 Boot error: 00 DD DD DD TX line remains low ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 27.672 s help me his soultion |
The Following 2 Users Say Thank You to saqi160 For This Useful Post: |
05-01-2010, 12:46 | #3 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | i tri with jab show its error Getting MCU ID Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Failed! Aborting! Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 7.34 20-10-05 RH-18 (c) NMP 1100 HW version: 0551 PCI version: UEM version: 1092 UPP version: 4609 RFIC version: 0300 DSP version: PEU2.14-@ LCD version: PHILIPS 2 3 PPM version: V 7.34 20-10-05 RH-18 (c) NMP 1100 AB Production serial number: PHD521389 Product code: 0510227 Module code: 0202128 Basic production code: 0510226 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356672002413561 IMEI spare to net: 3A 65 76 02 20 14 53 06 IMEI SV to net: 33 65 76 02 20 14 53 26 F0 Master Code: 4553013326 Phone type: RH-18, Software version: 7.34, Language Pack: AB User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-18.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0510227 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-18\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ae CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Italian Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ae CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Italian Setting local mode... Reading... Phone Type: RH-18 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ae CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Italian FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Setting local mode... Phone Type: RH-18 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ia CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,Farsi,French,Urdu Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 Booting phone... Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC This MCU ID is not supported in chosen flash file... Error booting phone... |
05-03-2010, 08:05 | #4 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | thanks to all brothers my problem is solve Getting MCU ID MCU ID: 0x1201 FLASH ID0: 88230020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 8.11 19-06-06 RH-18 (c) NMP 1100 HW version: 0551 PCI version: UEM version: 1092 UPP version: 4609 RFIC version: 0300 DSP version: PEU2.14-@ LCD version: PHILIPS 2 3 PPM version: V 8.11 19-06-06 RH-18 (c) NMP 1100 IA Production serial number: PHD521389 Product code: 0510227 Module code: 0202128 Basic production code: 0510226 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356672002413561 IMEI spare to net: 3A 65 76 02 20 14 53 06 IMEI SV to net: 33 65 76 02 20 14 53 26 F7 Master Code: 4553013326 Phone type: RH-18, Software version: 8.11, Language Pack: IA User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-18.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0510227 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-18\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ae CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Italian Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ae CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Italian Setting local mode... Reading... Phone Type: RH-18 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ae CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German,Italian FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Setting local mode... Phone Type: RH-18 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ia CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,Farsi,French,Urdu Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.110 Booting phone... MCU ID: 0x1201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88230020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x23882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: c0 Loader is ready... P-key nokia module version 01.02 MSID: 844993E872B5168185EC06862A MSID decoded: 3E4EBAE900D85AF6A9000000 FAID: FDF988E2C7EA2461680A91BF Operation took 0 minutes 6 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 011EFFFF... Erasing area: 011F0000 - 011FBFFF... Erasing area: 013F0000 - 013FBFFF... Erasing area: 017F0000 - 017FBFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-18\rh18_08.11ia Booting phone... MCU ID: 0x1201 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 88230020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x23882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B28; Loader chk: c0 Loader is ready... P-key nokia module version 01.02 MSID: 8402DF52C73B79DC3486D44C49 MSID decoded: 3E4EBAE900D85AF6A8000000 FAID: 6CDAB95C5F762F90465004A1 Operation took 0 minutes 6 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01170000 - 0117FFFF... Erasing area: 01180000 - 011EFFFF... Operation took 0 minutes 5 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 3 seconds... Restarting MCU... Flashing Done! Operation took 0 minutes 56 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-18, Software version: 8.11 IMEI: 356672002413561 Product Code: 0510227 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Done! Done! Powering the phone... Unlocking... IMEI: 356672002413561 ASIC: 2 SW version: 8.11 Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 1 Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 5 seconds... Done! |
