03-25-2011, 15:00 | #1 (permalink) |
Registered User Join Date: Aug 2010 Location: EVERY WHERE Age: 38
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | Nokia 1100 sl data crrupted (ANSWERED) SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: 5703000872537-4 Product Code: 0512486 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Ind,Tagalog Imei net: B5703000872537 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 BLOCK 1: 1.CORRUPTED CHAEK ITS IMEI ALSO |
03-25-2011, 15:24 | #4 (permalink) |
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | NOW I M FACHING THIS PROBLEM.....I WANT TO CHANGE ITS UEM ALSO.... Phone Type: RH-18 SW Version: V 8.11 19-06-06 RH-18 (c) NMP 1100 Imei plain: ??????????????-? Product Code: 0512486 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Ind,Tagalog Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Counter: 0/3, 0/10 CONFIG_DATA: DC0B152508960D14 PROFILE_BITS: B91B36675DFE9995 SIMLOCK_DATA corrupted! |
03-25-2011, 15:28 | #5 (permalink) |
No Life Poster Join Date: Jan 2010 Location: india Age: 43
Member: 1222236 Status: Offline Sonork: 100.1619169 Thanks Meter: 288 | imei rebuild or imei changes so simple connect the set with cable and make info then go to imei/security choose online logger put there username and password and last press DO JOB Last edited by gkmobiles; 03-25-2011 at 15:35. |
03-25-2011, 15:44 | #6 (permalink) | |
Member: 1372393 Status: Offline Sonork: I.M.STORE Thanks Meter: 90 | Quote:
now i got this message........ ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8823 [ST 58WR016FU,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0055E3FC:2984DA60 ASIC type: 2 UEM Imei: B5703000872537 Invalid uem checksum, UEM might be damaged ! [InternalErrorFault] IMEI/ESN (B5703000872537) contains non digit char, probably UEM damaged ! (case id=0xCB01) bow wht is this | |
03-26-2011, 02:39 | #8 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
you will need to change it. you can install already used uem chip, and do rpl repair. or use a new one, and do rpl otp write. - simply beyond economical repair. your skill on removing glued chip should be costly. BR | |
