nokia 1203 invalid imei checksum (ANSWERED) my nokia 1203 when i flash it on invalid imei checksum and on ppm file error Content extract fail, continue anyway ...logs MXKEY Serial: [FT SCR2000 0] - C08453AC Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.8.14.0, NTMP ver: 2.8.14.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0C32 2402 0100 0100 0201 0400 2082 0514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 006A5B7C:DA3BDA66 ASIC type: 11 UEM Imei: 35799503683450 Flash Imei: 24C54586F3204B Invalid imei checksum ! Processing MCU file: rh112_003.100 [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0C32 2402 0100 0100 0201 0400 2082 0514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 006A5B7C:2984DA60 Area [01000000-0100FFFF] erased in 1.062 s Area [01010000-013AFFFF] erased in 1 min 0.922 s Area [013B0000-013EFFFF] erased in 4.297 s Area [017C0000-017EFFFF] erased in 0.125 s Area [01FC0000-01FEFFFF] erased in 0.125 s Flash programming ... Programming completed in 18.141 s File Processed in 1 min 47.454 s Processing CNT file: rh1120_nai03.10ia [DCT4,DCT4 ALGORITHM] size: 165.96 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0300 8605 A401 20A2 2514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 006A5B7C:2984DA60 Area [01380000-013AFFFF] erased in 3.203 s Flash programming ... Programming completed in 1.360 s Content extract fail, continue anyway ... File Processed in 2 min 48.078 s Processing PPM file: rh112_003.10ia [DCT4,DCT4 ALGORITHM] size: 1002.02 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0300 8605 A401 20A2 2514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 006A5B7C:2984DA60 Area [01240000-0124FFFF] erased in 1.078 s Area [01250000-0137FFFF] erased in 20.078 s Flash programming ... Programming completed in 7.891 s File Processed in 57.453 s Total time for flashing process(boot+erase+write) was 5 min 33.015 s Phone not responding ! |
possible : Cable connectivity / Phone hardware pb . |
try to full erase (get addr, don't mark safe erase, do erase) and reflash. if phone is alive, proceed to repair imei. if phone still dead, check phone HW, most case bad flash chip. BR |
