01-15-2010, 11:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1003310 Status: Offline Thanks Meter: 28 | Nokia 1208 blue screen tried flashing no phone info phone in dead mode in flashing using safe flash rpl was saved but in the middle of flashing flashing terminated with with some rx2 error etc and with red colour phone not found also tried whole flash erase ticked but now shows contact service what can be done pls advice note: I have backup rpl I hope mx key can fix with great expectation |
01-15-2010, 17:24 | #5 (permalink) |
Member: 1003310 Status: Offline Thanks Meter: 28 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 Boot error: 02 FF FF 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Flashing terminated with error(s) in 42.875 s RX Buffer: |
01-15-2010, 17:50 | #6 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 55
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | most probably ur fone may have hardware fault. upp cause the main problems in 12XX fones , just dry and try again good luck NEIL |
nokia 1208 blue lcd | theonly1 | Nokia Hardware & Hardware Repair | 22 | 05-17-2012 16:13 |
1208 displays nokia then blue screen | shadowdex | Nokia Hardware & Hardware Repair | 8 | 08-16-2010 14:48 |
nokia 1208 blue display problem | saqi160 | Nokia Hardware & Hardware Repair | 7 | 11-13-2009 06:33 |
1208 blue screen | sr8787 | Nokia Hardware & Hardware Repair | 2 | 08-19-2009 23:30 |
nokia 1208 blue lcd problem | shaheb_anl | Nokia Hardware & Hardware Repair | 3 | 12-17-2008 14:42 |
