07-05-2010, 06:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan
Member: 644616 Status: Offline Sonork: 100.1608012 Thanks Meter: 257 | nokia 1208 can not unlock here is info Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rh105_06.000 as MCU [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C6BF7D:2984DA60 Area [01000000-0100FFFF] erased in 0.594 s Area [01010000-013AFFFF] erased in 32.281 s Area [013B0000-013EFFFF] erased in 2.125 s Area [017C0000-017EFFFF] erased in 1.797 s Area [01FC0000-01FEFFFF] erased in 0.094 s Flash programming ... Programming completed in 25.156 s File Processed in 1 min 13.218 s Processing file: rh1050_nai6.00ej as CNT [DCT4,DCT4 ALGORITHM] size: 114.90 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C6BF7D:2984DA60 Area [01380000-013AFFFF] erased in 1.735 s Flash programming ... Programming completed in 1.313 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 17.485 s Processing file: rh105_06.00ej as PPM [DCT4,DCT4 ALGORITHM] size: 1.15 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C6BF7D:2984DA60 Area [01240000-0124FFFF] erased in 0.594 s Area [01250000-0137FFFF] erased in 10.437 s Flash programming ... Programming completed in 12.766 s File Processed in 34.984 s Flashing completed in 2 min 5.750 s After Flash Processing ... Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Phone Type: RH-105 SW Version: V 6.00 30-09-09 RH-105 (c) NMP Imei plain: 35193103224066-6 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: EJ Language Pack: - not available. Failed to read SP data Total time to process is 2 min 12.703 s and here is unlock info Failed to read SP data Imei net is empty, process aborted. |
07-05-2010, 12:26 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
BR curvenger | |
07-05-2010, 14:12 | #3 (permalink) | |
Freak Poster Join Date: May 2010 Location: Bangladesh
Member: 1309082 Status: Offline Thanks Meter: 20 | Quote:
this phone try to cpu full rehot, after unlock i hope 100% solve your problem. br, parvez | |
