nokia 1208 rh 105 contact service pro hi to all brother s i i have nokia 1208 rh 105 its contect service i check with mx key and ufs on normal mode it s show contact service i sp unlock with mx key and ufs but problem same plz help me his soultion |
Read info and let us see logs! |
ok sir ............................ |
then post there |
sir i full erase the set and flash it and write good pm and unlock but problem not solve IMEI: 354222-03-***243-6, ASIC: 11 FILE: rh105_05.910 1st Boot: Ok, DCT4, UPP: 2292 [Rh-105] [2.1.0.0] 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2606,Sam K8S3215ETF Algorithm: u3_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84ABB31523A7306CC92DAEEA1C Decoded MSID: 3E4EBAE9-008FC808-A8000000 Encoded FAID: C8037FAC-4D51EDDB-8A3B7449 Area1: 0x01160000-0x0117FFFF Erased, Time: 00:00 PAT Flashing Completed, Time: 00:00 IMEI: 354222-03-188243-6, ASIC: 11 SimLocks Initialized (Patch Ok), Time: 00:00 SimLocks Initialized, Time: 00:25 UI Defaults Ok, Time: 00:02 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:01 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 info MCU SW : V 5.91 27-03-09 RH-105 (c) NMP PPM SW : V 5.91 27-03-09 RH-105 (c) NMP EL Prd.Code: 0550577 Bpr.Code: 0515534 Prod.Sn : DBM578929 HW Vers : 1600 UEM : 1328 UPP : 8850 [2292] RFIC Ver: 0700 DSP Vers: ICPR62_08w31_UPP LCD Type: WINTEK:NAXv84 ST7628 IMEI : 354222-03-188243-6 SL Conf : 001-01-00000000000 SL Prof : 000000000001000-B SL Var : 00003542220318824300 SL Aux : 000B0000 HW Sig : 12A76D84DAC81C28 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment |
contact service heat cp u.........4 contact service |
may be hardware problem. remove battery connector back side 2 compnents.n wash the charging connector . |
this is 100% hardware probleme, just reflow or reball cpu. |
