06-12-2012, 06:42 | #1 (permalink) |
Registered User Join Date: Jun 2011
Member: 1597393 Status: Offline Sonork: 6692766 Thanks Meter: 4 | Nokia 1280 cant reset.security code coruppted Using device: HTI, FW ver: 00.50, SN: 0000DB7B Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.13946(25-02-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Phone type: RM-647 SW version: V 06.51 13-05-11 RM-647 (c) Nokia Imei plain: 35904704059556-1 Product code: 0592303 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Security code: g b y Imei net: 35904704059556 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... Failed! (0102) Completed in 1 min 2.078 s PLS HELP |
06-12-2012, 07:14 | #7 (permalink) |
Freak Poster Join Date: Sep 2009 Location: GPG-Dragon Section
Member: 1115404 Status: Offline Sonork: 100.1618186 Thanks Meter: 134 | You Can Try To Reset Security Code Using This Option : Go Service-Imei & Security-User Code-Then Write There 12345 & Click On write Button |
06-12-2012, 07:57 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Click Buscheck & make phone go to Local Mode, now go to Service Tab>IMEI & Security>User Code>Click Read Code & Manually enter it to Phone & Reset it to Default is the easiest way to protect data & unlock Security Code. Best Regards, Zuber Chowdhry |
06-12-2012, 10:06 | #12 (permalink) | |
Freak Poster Join Date: Mar 2009
Member: 1001290 Status: Offline Thanks Meter: 81 | Quote:
