06-20-2010, 00:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | nokia 1680 v0682 Using device: UFS_USB V2.7 (c) SarasSoft 2005. Library version: 1.0.0.8814(13-06-2010), 1.0.0.14014(13-06-2010) RPL saved to "C:\mobileEx\3.4\data\backup\01168000304379_BACK.r pl" Processing file: rm394__06.82.mcusw as MCU [DCT4,DCT4 ALGORITHM] size: 10.19 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00013E7D:3B8ADA60 Area [01000000-0101FFFF] erased in 0.422 s Area [01020000-01C3FFFF] erased in 47.328 s Flash programming ... Programming completed in 3 min 4.375 s File Processed in 4 min 29.641 s Processing file: rm394__06.82.image_v as CNT [DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.63 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00013E7D:C5A4DA78 Area [02000000-02DBFFFF] erased in 1 min 13.875 s Area [02DC0000-02F9FFFF] erased in 11.125 s Converting UCP blocks to 128 K. Flash programming ... Programming completed in 1 min 35.063 s Extracting Content Pack, (c) Nokia File Server Content Pack extracted successfully in 0.140 s File Processed in 3 min 26.219 s Processing file: rm394__06.82.ppm_v as PPM [DCT4,DCT4 ALGORITHM] size: 3.10 MB Supported Ids: 3160, 3161, 3162, 3164, 3166 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00013E7D:2984DA60 Area [01C40000-01FFFFFF] erased in 15.515 s Flash programming ... Programming completed in 1 min 1.860 s File Processed in 1 min 29.812 s Flashing completed in 9 min 34.266 s Phone Type: RM-394 (Nokia 1680c-2) SW Version: V 06.82 26-09-08 RM-394 (c) Nokia Imei plain: 01168000304379-7 Imei OTP: 01168000304379 Product Code: 0573626 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: V Language Pack: - not available. Imei net: 01168000304379 Version: SIMLOCK SERVER Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 Total time to process is 9 min 45.531 s Imei net: 01168000304379 Version: SIMLOCK SERVER Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-394_01168000304379_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 01168000304379 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN ?????? |
