01-11-2011, 18:27 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | nokia 1800 new setup 1.8 bugs not flash Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...RX Buffer: 01AB i change three cable and use same pinout but this error please help |
01-12-2011, 11:20 | #6 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
The Following User Says Thank You to srinibas For This Useful Post: |
01-12-2011, 12:42 | #9 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | i change flash file now logs Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU: XGOLD 110 Sending EBL Loader ...OK Sending EBL ...OK BLS EPOCH/DATE/KEYFIX: SE0_091125 F11 Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version : Default_RAM_Bootloader Set baud rate to: 921600 Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing file: rm653_003.600 Downloading item CODE:hw_b2_rm653_r03.600.fls size: 4.08 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 42.953 s Erasing area 0x00C60000-0x00E6453E ...OK Programming completed in 41.843 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.141 s Checksum verified (0x4CDC) Processing file: rm653_003.60ia Downloading item CUST:hw_b2_rm653_003.60ia.fls size: 1.95 MB Erasing area 0x00210000-0x0040343E ...OK Programming completed in 40.313 s Checksum verified (0x36B9) Processing file: rm6530_nai03.60ia Downloading item CUST:hw_b2_rm6530_nai03.60ia.fls size: 334.08 KB Erasing area 0x00EB0000-0x00F02B3E ...OK Programming completed in 6.657 s Checksum verified (0x4D13) Total time for flashing process(boot+erase+write) was 3 min 53.969 s Phone not responding ! but set not power on please supporter help me |
01-13-2011, 13:28 | #11 (permalink) | ||
No Life Poster Join Date: Aug 2001 Location: Austria
Member: 5641 Status: Offline Thanks Meter: 72 | Have same problem with 1800 and v1.8, cant flash: Quote:
The Following User Says Thank You to DonaldDuck69 For This Useful Post: |
01-13-2011, 19:57 | #12 (permalink) | |
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
sir use cable 5.1 k or 7.5k please help me i make cable 7.5k and 5.1 k but my logs are under Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_b2_rm653_r05.800.fls from file rm653_005.800 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 39.547 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 43.421 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.031 s Checksum failed Processing CUST:hw_b2_rm653_005.80ia.fls from file rm653_005.80ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 37.610 s Checksum failed Processing CUST:hw_b2_rm6530_nai05.80ia.fls from file rm6530_nai05.80ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 6.282 s Checksum failed Flashing completed in 3 min 57.953 s Phone not responding ! | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
