01-25-2010, 15:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Nokia 2320 unlock problem >> Help needed Here is the phone info >>>> Phone Type: RM-514 (Nokia 2320c-2) SW Version: V 08.20 30-06-09 RM-514 (c) Nokia Imei plain: 0119750033xxxx Imei OTP: 0119750033xxxx Product Code: 0579480 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: QA Language Pack: - not available. Imei net: 0119750033xxxx Version: SIMLOCK SERVER Provider: CINGULAR - Pacific Bell Wireless, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3101700000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310150 BLOCK 2: 1.LOCKED (MCC+MNC): 310170 BLOCK 3: 1.LOCKED (MCC+MNC): 311180 BLOCK 4: 1.LOCKED (MCC+MNC): 310410 BLOCK 5: 1.LOCKED (MCC+MNC): 310980 Here is the error I get >>>> PhoneType:RM-514 SwVersion: V 08.20 30-06-09 RM-514 (c) Nokia MCU file: rm514__08.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! Cable is perfect, b'coz I flashed this handset with MT Box. Handset was originally rm-515. Help is needed >>> |
03-19-2010, 06:04 | #2 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 786178 Status: Offline Sonork: 100.1592104 Thanks Meter: 19 | hi 2320 AT&T U.S.A Successfully unlocked by MX KEY Procedure. 1= flash with rm-512 8.20 version 2= unlock 3= change filter 4= write pm 2330c 5= Enjoy with mxkey |
The Following User Says Thank You to gsmbee For This Useful Post: |
K800i UNLOCK PROBLEM URGENT HELP NEEDED.... | joebastian | SETool2 | 9 | 07-22-2008 15:07 |
u600 unlock problem urgent help needed | burraq | UST Pro II | 3 | 07-16-2008 20:19 |
CU720 unlocking problem....urgent help needed... | harim_1981 | VygisToolbox | 8 | 06-05-2008 15:46 |
Moto V177 Unlock Problem ( Help Needed Urgently ) | NadeemShahzad | Infinity-Box | 3 | 08-02-2006 12:28 |
