03-17-2010, 08:14 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Bangledashe ctg
Member: 884989 Status: Offline Sonork: 12000 Thanks Meter: 157 | nokia 2600 imei ??????????????-4 SW Version: V 4.42 18-01-05 RH-59 (c) NMP 2600 Imei plain: ??????????????-? Product Code: 0518475 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 5C98A9F2BABF88EF PROFILE_BITS: DB2454012BF932D1 BLOCK 2: 1.CORRUPTED (00) SIMLOCK_DATA corrupted! |
03-17-2010, 08:15 | #2 (permalink) |
Member: 884989 Status: Offline Sonork: 12000 Thanks Meter: 157 | ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0013C760:2984DA60 ASIC type: 2 UEM Imei: 35667500A53161 Invalid uem checksum, UEM might be damaged ! Connecting to server ...OK, Login ... Hello Cxxxxxxx, you have 860 credits left. Invalid DATA1 length, expected: 80 chars. |
03-17-2010, 09:13 | #6 (permalink) |
Member: 884989 Status: Offline Sonork: 12000 Thanks Meter: 157 | thanks friend my phone is ok thanks mx-key time i try to restore imei Easy Imei restore for DCT4 phones started. ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0013C760:2984DA60 ASIC type: 2 UEM Imei: 35667500A53161 Invalid uem checksum, UEM might be damaged ! Flash Imei: 35667500A53161 Investigating flash imei ... Calculating Imei restore ... ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0013C760:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. Phone Type: RH-59 SW Version: V 6.42 30-06-06 RH-59 (c) NMP 2600 Imei plain: 35667500:53161-5 Product Code: 0518475 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: AA Language Pack: English,Dannish,Norwegian,Swedish Imei net: 35667500A53161 Version: Counter: 0/3, 0/10 CONFIG_DATA: 27E8A23D8E0FD9B9 PROFILE_BITS: 9C980FA89A1D27D4 SIMLOCK_DATA corrupted! |
The Following User Says Thank You to forid For This Useful Post: |
2600 imei ???????????????4 | saeedullah_khan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-08-2010 12:00 |
2600 imei ??????????????4 | pdapower | Nokia Hardware & Hardware Repair | 4 | 01-14-2007 13:48 |
Can I change Nokia 2600 IMEI and How? | gsmfriend | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 08-18-2006 06:12 |
2600-imei ?????????????4 | D--arek | Nokia Digital Core Technology 4 ( DCT-4 ) | 31 | 07-27-2006 13:13 |
