10-22-2013, 23:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Nokia 2600c-2 Phone Restriction Nokia 2600c-2 RM-340 v 05.61 Code: 0569208 IMEI: 356397025070681 thanks |
10-23-2013, 00:10 | #2 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00821C97A3BDA66 ASIC type: 11 UEM Imei: 35639702507068 Flash Imei: 35639702507068 MasterCode: 3475501110 RPL saved to "C:\mobileEx\3.5\data\backup\35639702507068_BACK.r pl" Phone type: RM-340 (Nokia 2600c-2) SW version: V 05.61 18-04-08 RM-340 (c) Nokia Imei plain: 35639702507068-1 Imei OTP: 35639702507068 Product code: 0569208 Cellular system: GSM ASIC ID: 0x3162, type: 11 Ppm Id: T Language Pack: - not available. Master code: 3272005527 Camera config: GR0103D1012601022C00, ver: 001.003 Imei net: 35639702507068 Version: SIMLOCK SERVER Provider: Telstra Corporation Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050100058056920 PROFILE_BITS: 800000000001000B BLOCK1: 1=CLOSED(MCCMNC), DATA=50501F [Australia-Telstra Corporation Ltd. ] Imei net: 35639702507068 Version: SIMLOCK SERVER Provider: Telstra Corporation Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050100058056920 PROFILE_BITS: 800000000001000B BLOCK1: 1=CLOSED(MCCMNC), DATA=50501F [Australia-Telstra Corporation Ltd. ] Calculating SIMLOCK RPL ... Rpl backup saved to "C:\mobileEx\3.5\data\backup\RM-340_35639702507068_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35639702507068 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000001000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
