Cheater -Don't Deal with him-
Member: 635691
Sonork: 100.1592330 Thanks Meter: 137 | Nokia 2610 Contact service Help Nokia 2610 in Contact Service
if i powre on the phone with battry he show contact service in screen.
if i powre on the phone by cable by using normale mode he work fine.
here is the log: Quote:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
ASIC ID: 0x3040 [UPP_4M ver: 4.1]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 000FFE6AA3BDA66
ASIC type: 11
UEM Imei: 3598260xxxxxxx
Flash Imei: 35982601xxxxxxx
MasterCode: 5461xxxxx
RPL saved to "C:\mobileEx\3.3p\data\backup\35982601224755_BACK. rpl"
Phone Type: RH-86 (Nokia 2610)
SW Version: V 07.11 05-11-08 RH-86 (c) Nokia.
Imei plain: 35982601xxxxx-x
Product Code: 0537020
Cellular System: GSM
ASIC ID: 0x3040, type: 11
Ppm Id: IC
Language Pack:
English,Arabic,French,Swahili
TimeStamp: 2008-05-09T06:17:11Z
SW Version: 06.73
Variant Version: 034
ProductProfile: RH86_0537020_06.73_034.spr
Simlock: 0537020_simlock.txt
Imei net: 359826xxxxxxx
Version: SIMLOCK SERVER VERSION 63
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
Flash Log: Quote:
Rpl backup already exist (C:\mobileEx\3.3p\data\backup\35982601224755_BACK. rpl).
Processing file: rh86_87__07.11.mcusw as MCU
[DCT4,DCT4 ALGORITHM] size: 8.64 MB
Supported Ids: 3040
UEM ID: 000FFE6A:2015DA60
Area [01000000-0101FFFF] erased in 0.765 s
Area [01020000-018DFFFF] erased in 52.532 s
Area [01EE0000-01FDFFFF] erased in 6.843 s
Flash programming ...
Programming completed in 2 min 21.953 s
File Processed in 3 min 30.688 s
Processing file: rh86_87__07.11.image_ctv_me_gulf_v2 as CNT
[DCT4,DCT4 ALGORITHM] page size: 64 K size: 1.44 MB
Supported Ids: 3040
UEM ID: 000FFE6A:C5A4DA78
Area [01B80000-01EDFFFF] erased in 21.375 s
Converting UCP blocks to 128 K.
Programming completed in 21.875 s
Extracting Content Pack, (c) Nokia File Server
Content Pack extracted successfully in 0.047 s
File Processed in 1 min 4.531 s
Processing file: rh86_87__07.11.ppm_ic as PPM
[DCT4,DCT4 ALGORITHM] size: 1.56 MB
Supported Ids: 3040
UEM ID: 000FFE6A:2984DA60
Area [018E0000-01B7FFFF] erased in 16.469 s
Programming completed in 26.094 s
File Processed in 51.266 s
Flashing completed in 5 min 27.406 s
After Flash Processing ...
Reseting Factory Values OK.
PhoneType:RH-86
SwVersion: V 07.11 05-11-08 RH-86 (c) Nokia.
MCU file: rh86_87__07.11.mcusw
Trying to find patch position ...OK, case id: 2
Area [010A0000-010BFFFF] erased in 0.844 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Area [010A0000-010BFFFF] erased in 0.843 s
Programming ...
Completed in 45.265 s
Imei plain: 3598260xxxxx-x
Ppm Id: IC
Language Pack:
Imei net: 3598260xxxxxx
Counter: 0/3, 0/10
Total time to process is 6 min 29.656 s | |
