05-02-2012, 21:00 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: At Work always
Member: 885483 Status: Offline Thanks Meter: 15 | Nokia 2730 from bell problem SW version: V 10.45 05-07-10 RM-579 (c) Nokia Imei plain: 35605803755534-7 Product code: 0588611 Battery voltage: 4717 mV, current: 127 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR030102F201, ver: 006.006 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356058037555347 Version: SIMLOCK SERVER Provider: Bell Mobility , Country: Canada Counter: 0/3, 0/10 CONFIG_DATA: 3026100076705775 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN, 2=OPEN BLOCK2: 1=OPEN, 2=OPEN BUT PHONE SAYS PHONE RESTRICTED HOW TO SOLVE.. |
05-03-2012, 06:13 | #2 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: srilanka Age: 39
Member: 1133072 Status: Offline Thanks Meter: 505 | Quote:
post self test log B,R-chamisrilanka | |
05-03-2012, 17:29 | #3 (permalink) |
Member: 885483 Status: Offline Thanks Meter: 15 | this is slef test log Phone Type: RM-579 SW version: V 10.45 05-07-10 RM-579 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y PASSED(00) 12 SIM_CLK_LOOP Y PASSED(00) 13 SIM_IO_CTRL_LOOP Y PASSED(00) 15 SLEEP_X_LOOP Y PASSED(00) 46 UEM_CBUS_IF Y PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 43 LCD N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO N !NOT EXECUTED(03) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 101 BTEMP N !NOT EXECUTED(03) 119 IIC N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 82 CDSP_PWR_DETECTOR_BIAS N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
05-03-2012, 19:25 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. select & run all in self test, yours is incomplete test, by the way check BB5 certificate validation. br, |
05-04-2012, 11:17 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. means to say, you just click selftest & post logs, but you didn't initialize & run all thereafter, if you again try as i mention then you will see many changes in logs from your last one (like test PASSED instead of NOT EXECUTED), will also help in solve too. best regards, |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
05-04-2012, 14:15 | #8 (permalink) |
Member: 885483 Status: Offline Thanks Meter: 15 | here is new self test log Phone Type: RM-579 SW version: V 10.45 05-07-10 RM-579 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO N passed 69 BACKLIGHT Y passed 33 SIM_LOCK N passed 93 SECURITY N passed 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N !no signal 86 CDSP_RF_BB_IF N !no signal 83 CDSP_RF_SUPPLY N !no signal 85 CDSP_TX_IQ N !no signal 74 CDSP_TXC_DATA N !no signal 82 CDSP_PWR_DETECTOR_BIAS N !no signal 79 CDSP_RX_PLL_PHASE_LOCK N !no signal 80 CDSP_TX_PLL_PHASE_LOCK N !no signal 75 CDSP_WCDMA_TX_POWER N !no signal 81 CDSP_RX_IQ_LOOP_BACK N !no signal 77 CDSP_GSM_TX_POWER N !no signal Last edited by rroach59; 05-04-2012 at 14:17. Reason: but phone still says enter restriction code |
05-04-2012, 14:23 | #9 (permalink) |
Member: 885483 Status: Offline Thanks Meter: 15 | also these are codes for phone 356058037555347.sha #pw+300567411983786+1# #pw+262543860831124+2# #pw+785323906965407+3# #pw+805374523593066+4# #pw+650073789794576+5# #pw+708508868366176+6# #pw+085332308579017+7# TRIED ALL CODE WHEN ASKED FOR RESTRICTION CODE BUT NOT WORKED, what to do now ?. |
05-04-2012, 15:03 | #10 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. just want to see selftest & no hardware issue, now take full RPL & PM Backup, erase flash with untick safe erase, flash it with latest firmware with same product market, after complete flashing restore IMEI, go to PM tab load PM & click write & yes to popup window ask, now go to Simlock tab & tick unlock by code & you have the codes for it, click Update SpLock. Now post your result & have a Nice Day.......... Best Regards, Zuber Chowdhry |
