nokia 300 nokia 300 rm-781 thise phone without sim work normaly but insert sim go to phone off flash thise but same help bus check logs MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0856E16 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00005C74 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 3E690000FFFB3C40D8DA5A1D2F9785D8631C43CE CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3B52DF0E FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 9C9241FD29D3EDB35B15180A7DD9692987B4EE7C Selected firmware certificate matched. Original Imei: 35168605160933 Original Product code: 059J876 Bluetooth ID: 940070EA0191 SIMLOCK PA identifier: [0] PA_SIMLOC30 Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 4DEC341 Verifying communication to device OK. Phone type: RM-781 (Nokia 300) SW version: V 07.65 31-10-12 RM-781 (c) Nokia Imei plain: 35168605160933-8 Product code: 059J876 Battery voltage: 3791 mV, current: 158 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 0F03F840002004, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 351686051609338 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
Bro. Lools like Hardware, Run & Post Selftest logs for assistance. BR, ZUBER |
Phone Type: RM-781 SW version: V 07.65 31-10-12 RM-781 (c) Nokia ID Test name Startup Result 232 USB_CHARGER N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 15 SLEEP_X_LOOP N !NOT EXECUTED(03) 46 UEM_CBUS_IF Y PASSED(00) 3 EAR_DATA_LOOP N !NOT EXECUTED(03) 12 SIM_CLK_LOOP N !NOT EXECUTED(03) 33 SIM_LOCK N PASSED(00) 93 SECURITY N PASSED(00) 90 PWR_KEY N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 69 BACKLIGHT Y PASSED(00) 20 BACKUP_BATT Y PASSED(00) 43 LCD N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 22 CAMERA_IF N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 8 MBUS_RX_TX_LOOP Y PASSED(00) 23 KELVIN_BATVOLTAGE N !NOT EXECUTED(03) 19 KELVIN_VIBRA N !NOT EXECUTED(03) 26 KELVIN_CAPACITOR N !NOT EXECUTED(03) 29 KELVIN_MISC N !NOT EXECUTED(03) 31 KELVIN_CHARGING N !NOT EXECUTED(03) 27 KELVIN_AUDIO N !NOT EXECUTED(03) 116 KELVIN_XEAR N !NOT EXECUTED(03) 60 TOUCH_STUCK N !NOT EXECUTED(03) 103 TOUCH_IF N !NOT EXECUTED(03) 105 INTERNAL_ANTENNA N PASSED(00) 119 IIC N !NOT EXECUTED(03) 91 USB_LOOP N !NOT EXECUTED(03) 117 DIGIMIC N !NOT EXECUTED(03) 222 LED_CONTROLLER N !NOT EXECUTED(03) 239 RAM_IF N !NOT EXECUTED(03) 128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 124 CDSP_STROBE N !NOT EXECUTED(03) 125 CDSP_DIGI_RXTX_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 127 CDSP_PA_ID_PIN N !NOT EXECUTED(03) 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) |
Bro. This is not full Logs, Click on Initialise Button again will get complete Selftest. BR, ZUBER |
reheat the cpu and re flash the unit again........... |
