02-01-2012, 05:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: chhattisgarh india
Member: 533010 Status: Offline Thanks Meter: 16 | Nokia 3110 contect service pls help me MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0853E81 Using device: HTI, FW ver: 00.24, SN: 0000341B Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 13600203E8BD7E56C8B2857F19D6A7A04AC30F5D ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D TransmissionMode: DDR&TX2 Original Imei: 35322503484410 Original Product code: 0581437 Bluetooth ID: 002547AD3D49 Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35322503484410-6 Product code: 0581437 Battery voltage: 4221 mV, current: 65 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 353225034844106 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
02-01-2012, 05:30 | #2 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | lol... search bro! too lazy?? check here then: http://forum.gsmhosting.com/vbb/f550...ailed-1214364/ good luck bro br |
The Following User Says Thank You to specta For This Useful Post: |
02-01-2012, 05:36 | #3 (permalink) |
No Life Poster Join Date: Jul 2011 Location: india Age: 44
Member: 1623262 Status: Offline Sonork: 100.1621312 Thanks Meter: 96 | ur simlock also failed........so if u have backup then write otherwise u have to buy new rpl for it. |
The Following User Says Thank You to unuunu For This Useful Post: |
02-01-2012, 05:39 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: I.N.D.I.A
Member: 385162 Status: Offline Thanks Meter: 598 | 1st repair simlockdata after repairing simlock you need to write full pm with sx4.. |
The Following User Says Thank You to dharmeshslnk For This Useful Post: |
02-01-2012, 06:10 | #7 (permalink) |
Member: 533010 Status: Offline Thanks Meter: 16 | Same problem bro. Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35322503484410-6 Product code: 0514950 Battery voltage: 4258 mV, current: 67 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Imei net: 353225034844106 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
The Following User Says Thank You to rajkamal_kasdol For This Useful Post: |
02-01-2012, 06:17 | #8 (permalink) |
Member: 533010 Status: Offline Thanks Meter: 16 | Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35322503484410-6 Product code: 0581437 Battery voltage: 4256 mV, current: 67 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353225034844106 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F |
02-01-2012, 06:18 | #9 (permalink) |
Member: 533010 Status: Offline Thanks Meter: 16 | Security test failed Imei net: 353225034844106 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0853E81 Using device: HTI, FW ver: 00.24, SN: 0000341B Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Phone type: RM-237 (Nokia 3110c) SW version: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData. PUBLIC ID: 13600203E8BD7E56C8B2857F19D6A7A04AC30F5D PRIVATE ID: C38A4F24FEC0E8B1AA7C3EAF66B64C78E92678B3 Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 353225034844106 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
