05-10-2010, 09:12 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Inside Technology
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 330 | Nokia 3110c security test failed not done!! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.21 05-11-08 RM-237 (c) Nokia. Using cached productData[19E0010862FA7B561B57C21041C8F58903052FE2] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request AND AFTER THAT Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35XXXXXXXXXXXXXXX Product Code: 0550542 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! "RM-237" folder created. Imei net: 35XXXXXXXXXXX Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF WHAT TO DO NOW? |
The Following User Says Thank You to mmrozibul For This Useful Post: |
05-10-2010, 09:27 | #3 (permalink) |
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 330 | Already done but problem still same. tryed this backup rpl rest npc go to pm click erase pm writ rpl then click recover cert repair sd (you will get rpl to repair sim & sd) go to pm >click SUPER SD AUTH and writ pm fullfactory |
05-10-2010, 09:36 | #7 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Actually i was faced with this kind of problem Need 2 mention that in some cases i get message but it was bug on SW coz others dont shows that problem So Suggestion is to write rpl wo npc data repair sd sd autor sx write Pm Regards |
The Following User Says Thank You to Formingus For This Useful Post: |
05-10-2010, 09:39 | #8 (permalink) |
Freak Poster Join Date: Jan 2009 Location: india
Member: 952226 Status: Offline Thanks Meter: 20 | make rpl back up then erase flash with pm file flash with latest file . write pm restore imei back up |
The Following User Says Thank You to sanoj2 For This Useful Post: |
05-10-2010, 09:42 | #10 (permalink) |
Member: 322417 Status: Offline Thanks Meter: 940 | ok write thuse u have full with removed 308 and second is only 1 and 309 and remeber ur problem is at PM u shuld only found good PM i ask from mine friend if hi come onlyne i will upload that one that i repair mine 3100c Regards |
05-10-2010, 10:03 | #13 (permalink) |
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 330 | I done all the steps avobe but problem remaining same!! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 07.30 07-05-09 RM-237 (c) Nokia. Using cached productData[19E0010862FA7B561B57C21041C8F58903052FE2] ... Authenticating to SUPERDONGLE using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.0 revision 1.7 Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
