09-08-2009, 08:22 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | serious bug in mx key! RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM1 ID: 00000296 EM2 ID: 00000B22 PUBLIC ID: 16A0020BB4757F56CA3E3375570F2595A5F925F8 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS ID: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35524603855299 Original Product code: 0576616 Bluetooth ID: 0025D0DDE04F Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.65 01-04-09 RM-495 (c) Nokia Imei plain: 35524603855299-8 Product Code: 0576616 VariantId: S Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF by JAF Powering the phone... Reading... MCU SW version: V 06.65 01-04-09 RM-495 (c) Nokia HW version: 2000 PCI version: RFIC version: 06560601 LCD version: SEIKO PPM version: V 06.65 01-04-09 RM-495 (c) Nokia SSA Retu version: 16 Tahvo version: 22 Content Pack version: Content: ssa_g_red V 06.65 01-04-09 RM-495 (c) Nokia Production serial number: IBW345013 Product code: 0576616 Module code: 0204024 Basic production code: 0567772 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 355246038552998 IMEI spare to net: 3A 55 42 06 83 55 92 09 IMEI SV to net: 33 55 42 06 83 55 92 39 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-495.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0576616 Searching for JAF saved location of ini... Checking path: D:\Products\RM-495\ Searching for default location of ini... Checking path: D:\Products\Products\RM-495\ Searching for JAF saved location of ini... Checking path: D:\Products\RM-495\ Scanning ini files... Searching for default location of ini... Checking path: D:\Products\Products\RM-495\ Checking path: D:\Products\RM-495\ FILES SET FOR FLASHING: MCU Flash file: D:\Products\RM-495\rm495__06.65.mcusw PPM Flash file: D:\Products\RM-495\rm495__06.65.ppm_aa CNT Flash file: D:\Products\RM-495\rm495__06.65.image_aa_red APE Variant file: NONE Done! By MT BOX Phone is in: Local mode Scanning files, please wait... Done WARNING: THE VERSION YOU SELECTED: 06.65 is NOT the highest installed!!! the highest available is: 06.93 Model: RM-495 ( RM-495) V 06.65/01-04-09/RM-495 (c) Nokia Production serial number IBW345013 Product code 0576616 Module code 0204024 Basic production code 0567772 Flash code Order number Long production SN 0 MCU SW V 06.65/01-04-09/RM-495/(c) Nokia HW 2000 PCI RFIC 06560601 DSP ICPR72_09w03 LCD SEIKO PPM V 06.65/01-04-09/RM-495/(c) Nokia /SSA BT MCM 2222-143C Retu 16 Tahvo 22 Content Pack Content: ssa_g_red/V 06.65/01-04-09/RM-495/(c) Nokia / IMEI: 355246038552998 WARNING: VPP pin is not connected, disabling VPP. V 06.65/01-04-09/RM-495 (c) Nokia IMEI: 355246038552998 Operator: 2440700000000000 Operator Name: AT&T;U.S.A. (3650) Profile bits: 0000000000000000 Sim Status: Not locked there is a bug when reading sim lock state with MX KEY for nokia 5130!!!!! |
09-08-2009, 08:32 | #2 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | you must when ever next time your fell any buy then you need to post in this thread http://forum.gsmhosting.com/vbb/showthread.php?t=687026 |
bug´s mx key 3.3 rev 1.7 | bvcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-22-2010 14:44 |
2700 flashing error i think its bug in mx key | ashokassag | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-23-2010 12:00 |
SD Auth in Mx-key Good news for mx-key user | muksforu | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-28-2010 12:02 |
Plese post dct4 flash bug in mx-key | debmobile | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 08-21-2009 18:37 |
bug in mx key solution needed | mbiborna | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 08-19-2009 00:34 |
