Nokia 3230 Flash Imei: FE7564BE18DF60 ....................????? ASIC ID: 0x1081 [UPP_WD2 ver: 3.1] w3_2nd.fia: [WD2 BT2] version: 4.70.1 revision: 0.7 size: 0x10D8 Supported Ids: 1080, 1081 FlashID0: 00EC DDFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC EEFE [Samsung K8S5615ETA,128 Mbits] page size: 64 K type: NOR area: 02000000-02FFFFFF FlashID2: 00EC 2250 [Samsung K8S6415ETB,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF FlashID3: 0000 0001 [unused/removed] ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA w3_amd.fia: [WD2 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7F10 Supported Ids: 1080, 1081 Performing Flash Authentication ...OK UEM ID: 0017B044:2984DA7E ASIC type: 5 UEM Imei: 35455301880151 Flash Imei: FE7564BE18DF60 MasterCode: ED5346F81A Invalid imei checksum ! Phone not responding ! flashing, unlocking write pm and write rpl but prb is still same |
RESET DATA 1. write RPL calculation if still have same problem , change your flash ic . ( here Samsung K8S5615ETA ) br, |
this problem wont slove by rpl its hw problem in ic flash wbr |
hi, i think its a bug from the software itself... i experienced that on 6600... maybe WD2 has that bug, hope alim will check for it... |
we say "BUG" if by all user. maybe u can post LOG to if that BUG br, |
wd2 have only 2 bug here thats we will fix next update cant reconect phone in flash mode state after flashing mcu(u need 2 flash mcu and ppm alone) 2.cant detect file system format |
