Old 08-07-2014, 15:43   #1 (permalink)
AUN_KHALIL's Avatar
Member: 821450
Sonork: khalil_lush
Thanks Meter: 269
asha 305 flash with wrong frimware
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0810915
Using device: USB ROM and HTI, FW ver: 00.50, SN: 01012A9A
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.117
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.49
EBL version: Quantum_Bootloader_10.49_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Processing file: rm766__07.42.mcusw
Downloading item CODE:rm766__07.42.mcusw_ebl_psi.fls, num block: 4, size: 27.77 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.422 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.391 s
Erasing area 0x40060000-0x4011FFFE ...OK
Programming completed in 1.484 s
Erasing area 0x40120000-0x41BE3FFE ...OK
Programming completed in 40.953 s
Checksum verified (0x9E48)
Processing file: rm766__07.42.ppm_maa
Downloading item CUSTackage_maa.ppm_ebl_psi.fls, num block: 1, size: 5.76 MB
Erasing area 0x41C00000-0x421C189E ...OK
Programming completed in 8.828 s
Checksum verified (0xC270)
Processing file: rm766__07.42.image_maa_059L1H0
Downloading item CUSTackage_maa_059L1H0.image.fls, num block: 1, size: 14.13 MB
Erasing area 0x42400000-0x43EDFFFE ...OK
Programming completed in 21.344 s
Checksum verified (0x25FD)
Total time for flashing process(boot+erase+write) was 3 min 44.484 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
set is dead now ..... working ok before flash
Old 08-08-2014, 16:27   #2 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
CPU: XGOLD 213
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
1 Block regions:
EBL ready !
Flash with right firmware phone will be alive!
Old 08-09-2014, 08:48   #3 (permalink)
AUN_KHALIL's Avatar
Member: 821450
Sonork: khalil_lush
Thanks Meter: 269
already did but not solve .
just vibrate and blue lcd then off
Old 08-10-2014, 20:17   #4 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Flash with same product code and latest version,
Old 08-11-2014, 04:24   #5 (permalink)
AUN_KHALIL's Avatar
Member: 821450
Sonork: khalil_lush
Thanks Meter: 269
did it but same condition
Old 08-17-2014, 06:31   #6 (permalink)
AUN_KHALIL's Avatar
Member: 821450
Sonork: khalil_lush
Thanks Meter: 269
Mxkey team support me how to solve it
Old 08-23-2014, 16:47   #7 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
First flash with ENO file then flash same product code
Page generated in 0.17730 seconds with 8 queries
