10-03-2013, 14:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Nokia 501 White Display MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C086D6ED Using device: USB ROM and HTI, FW ver: 00.50, SN: 01006630 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm902_10.0.14.mcusw.fpsx [XG223,XG223_V0 ALG] size: 28.21 MB Supported Ids: 00000C2016100040 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 00000C201610004049B2220992A468328189FB00 [XGOLD 223] CMT PUBLIC ID: F8AB4F5C2EAC3BA149B2220992A468328189FB00 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 125FC72605B5C4E48A9E0225084D2579 CMT ROM ID: 535882252F54C676 Loading CMT secondary boot code SecondaryBoot: XG223_v11_usb2nd.fg [XG223] version: 12.30.1 revision: 4.0 size: 0x59C0 Supported Ids: 00000C2016000040, 00000C2016100040 Secondary boot loaded. Loading CMT update server data Algorithm: XG223_v11_usbalg.fg [XG223_V0 ALG] version: 12.30.1 revision: 4.0 size: 0x32338 Supported Ids: 00000C2016000040, 00000C2016100040 Update server code loaded. Initializing Update Server ... Configuring Algorithm clients... FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 57 MB CMT FLASH,NOR area [40000000-4003FFFF] CMT FLASH,NOR area [47E00000-47E3FFFF] CMT FLASH,NOR area [40060000-426FFFFF] CMT FLASH,NOR area [42700000-437FFFFF] CMT FLASH,NOR area [47E40000-47F1FFFF] Flash programming ... CMT ISSW block sent CMT MEMSET block sent CMT PRIMAPP block sent CMT LOADER block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7E4AA995 [] sent CMT UPDAPP block sent CMT MCUSW block sent Programming completed in 21.734 s Processing PPM file: rm902_10.0.1_059R2T6_m1_245_01_247952.rofs.fpsx [XG223,XG223_V0 ALG] size: 4.82 MB Supported Ids: 00000C2016100040 Erase size: 17 MB CMT FLASH,NOR area [42700000-437FFFFF] erased in 0.015 s Flash programming ... CMT PPM block sent Programming completed in 1.531 s Processing CNT file: rm902_10.0.1_059R2T6_m1_245_01_247952.image.fpsx [XG223,XG223_V0 ALG] size: 25.75 MB Supported Ids: 00000C2016100040 Erase size: 70 MB CMT FLASH,NOR area [43800000-47DFFFFF] erased in 0.031 s Flash programming ... Programming completed in 18.422 s Total time for flashing process(boot+erase+write) was 55.140 s Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1DB32C29 Waiting for USB device removal ... Any solution |
