10-24-2010, 10:17 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Nokia 5030 imei not valid!!! (answered & closed) any simple steps??? WBR |
10-24-2010, 10:32 | #3 (permalink) |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Here is log: ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00377084A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RM-524 SW Version: V 05.01 23-09-09 RM-524 (c) Nokia Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MG Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! |
The Following User Says Thank You to msashami For This Useful Post: |
10-24-2010, 10:33 | #4 (permalink) | |
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | Quote:
ya i did but no luck. says "access voilation at address..., read of address: 0000000" what's next??? WBR | |
10-24-2010, 15:01 | #10 (permalink) | |
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00377084A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RM-524 SW Version: V 05.01 23-09-09 RM-524 (c) Nokia Imei plain: ??????????????-? Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: MG Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! | |
10-24-2010, 22:03 | #13 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | you got an empty OTP on phone. You should fill it properly. Add an extra voltage on vbatt (5 v) while doing write rpl on such phone. use rpl file that you already made. |
