02-09-2010, 11:08 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: peshawar
Member: 668816 Status: Offline Sonork: no Thanks Meter: 182 | Nokia 5130c Only SUPERDONGL problem. will be fixed by Mxkey? ================================== his is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-08-05T07:40:36Z SW Version: 06.94 Variant Version: 010 ProductProfile: RM495_0571952_06.94_010.spr Simlock: 0571952_simlock.bin Imei net: 354223037804499 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
The Following User Says Thank You to hussainafridi For This Useful Post: |
02-09-2010, 11:22 | #2 (permalink) |
Freak Poster Join Date: Aug 2008 Location: PhiIippines
Member: 847117 Status: Offline Thanks Meter: 71 | 1. open: service> imei & security> REPAIR SD(if DONE proced to atep 2) 2. open: PM> SUPER SD 3. tick LOAD FROM FILE (select PM 1 and 309 area only) 4. tick WRITE when PM writing is DONE to check if phone is OK, tick again BUS CHECK GOOD LUCK Last edited by xannix_7575; 02-09-2010 at 11:27. |
The Following User Says Thank You to xannix_7575 For This Useful Post: |
02-09-2010, 11:33 | #5 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | Quote:
here it's full good pm: http://www.zshare.net/download/7233646573190e18/ b.r. | |
The Following 2 Users Say Thank You to bk.gsm For This Useful Post: |
02-09-2010, 11:37 | #6 (permalink) | |
Member: 847117 Status: Offline Thanks Meter: 71 | Quote:
and here http://rapidshare.com/files/34812952...5_5130.pm.html | |
02-09-2010, 13:05 | #11 (permalink) |
Member: 668816 Status: Offline Sonork: no Thanks Meter: 182 | Yes don my problem, thanks @ xannix_7575 and @the scavenger Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35422303780449-9 Product Code: 0571952 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-08-05T07:40:36Z SW Version: 06.94 Variant Version: 010 ProductProfile: RM495_0571952_06.94_010.spr Simlock: 0571952_simlock.bin Imei net: 354223037804499 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 5.875 s |
The Following 2 Users Say Thank You to hussainafridi For This Useful Post: |
02-09-2010, 13:08 | #12 (permalink) |
Freak Poster Join Date: Jan 2007 Location: DREAM HOME
Member: 429744 Status: Offline Thanks Meter: 93 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: F042C4012258B474E505C08E8E81323025D86C4E ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002200 [RAP3G ver: PA 2.2] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 1F800107746B5D514513253695A3E241BC36CB82 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 2250 - 0000 0121 [Samsung K8S6415ETB,64 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 0098 0036 - 00A5 00C0 [Toshiba 512 DDP NAND,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Original Imei: 35696301667219 Original Product code: 0524110 Bluetooth ID: 001C9A473753 Phone Type: RM-84 (Nokia N70) SW Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. Imei plain: 35696301667219-7 Product Code: 0524086 ApeCoreSw: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia ApeVariant: V 5.0737.3.0.1-29.01 13-09-07 RM-84 (c)Nokia. Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356963016672197 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED how can i do |
The Following User Says Thank You to billal930 For This Useful Post: |
02-09-2010, 13:20 | #13 (permalink) | |
Registered User Join Date: Jun 2007 Location: Kabirwala/Punjab/ Pakistan
Member: 536592 Status: Offline Thanks Meter: 210 | Quote:
your problem will be solved | |
02-09-2010, 13:31 | #14 (permalink) |
Freak Poster Join Date: May 2004 Location: Silent Mode Age: 39
Member: 65656 Status: Offline Thanks Meter: 91 | 5130c / sl3 can repair with magic mx-key but, only this can repair PHP Code: Code: SIMLOCK seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Code: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Code: CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Code: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed done. if before, Code: SIMLOCK invalid! |
nokia 6124c-1 rm-422 by vodafone cant be unlocked by mxkey (ANSWERED) | med26 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 07-17-2011 21:37 |
Do you think will be nice if MXKEY will make ATF as supported interface ? | MANOLE | Advance-Box | 229 | 11-28-2010 12:10 |
- Stop Complaing - Server Will Be Fixed - | Kevbodian | Dongle Problems (USB-Smart) | 23 | 09-04-2006 01:42 |
When will be fixed bug?!? | systemworm | JAF Xtras | 5 | 07-30-2006 07:29 |
When IT WIll BE FIXED...............:-( | .::BHATTI::. | FuriouS II | 0 | 12-29-2005 17:02 |
