Old 05-13-2010, 15:06   #1 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
Nokia 5130c sd repair for mxkey yes or no??????
Old 05-13-2010, 15:12   #2 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
s.u can do.........just reppair sd.then writ rpl pm.............
Old 05-13-2010, 15:14   #3 (permalink)
Member: 900556
Sonork: 100.1580217
Thanks Meter: 37
no sl3 not supported at yet
Old 05-13-2010, 15:15   #4 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
Not sim lock only superdongle key BUT SERVER IS DWON
Old 05-14-2010, 00:11   #5 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
All server are up and running well. probably you are using an old version of
mxkey software. Please read news about last update:
http://forum.gsmhosting.com/vbb/5793184-post85.html
- Due to keep the server stability, older server will be removed and all older releases are obsolete.
BR,
Manole
The Following 3 Users Say Thank You to MANOLE For This Useful Post:
Old 05-14-2010, 01:34   #6 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
u can repair sd with mx
but after repair sd u need to write the fields of pm(1 & 309)
use super sd auth to write pm not pmm auth
The Following User Says Thank You to ahmad yousif For This Useful Post:
Old 05-14-2010, 05:39   #7 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 120
Please help me my repair sd,simlock repair,sign application is working but sd auth and pmm is not working for past 9 days,is my dongle or ip or what please help me.
The Following User Says Thank You to wisdom001 For This Useful Post:
Old 05-14-2010, 07:06   #8 (permalink)
Member: 764174
Thanks Meter: 259
remove any old mx old software and install the latest
and try many times with ppm auth or super pm auth sometimes srever busy
if not solve use recover cert or edit rpl manual
and try again
Old 05-14-2010, 14:05   #9 (permalink)
d.jain's Avatar
Member: 670629
Sonork: 100.1590208
Thanks Meter: 431
after update sd ihave wright pm but see this
Using device: POTATO BOX, FW ver: 01.B4
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 06.65 01-04-09 RM-495 (c) Nokia
Using cached productData[0F50021836027D5667F882089014A071BA4F68C4] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 05-14-2010, 20:17   #10 (permalink)
Member: 764174
Thanks Meter: 259
try to recover cert or try to edit rpl manual
then retry to reconnect to server again & again tell phone respond to super sd auth & write the 2 fields of pm
post result
Old 05-14-2010, 22:18   #11 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
Follow manole steps
You need to write CORRECT PM or as alternative use 'Load RF/BB from Server' so sw will
request PM from server and write to the phone.
The Following User Says Thank You to alasmmar For This Useful Post:
Page generated in 0.19676 seconds with 9 queries
