03-19-2010, 14:25 | #1 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1003310 Status: Offline Thanks Meter: 28 | Nokia 5220 RM-411 goes to white screen A strange problem phone working ok but after some time the screen goes to white but when any key is pressed screen comes back normally.also when tried to flash gives the message Error while programming [00] at 0x000582C0, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 41.797 s RX Buffer: F372 now the phone is dead even though the flash file is the latest one also the phone also has the same version.also when scanned says protected sd avoid sw downgrade.is this a sl3 phone. pls advice |
03-19-2010, 15:22 | #3 (permalink) | |
Freak Poster Join Date: Apr 2009 Location: QQ:2557307931
Member: 1010502 Status: Offline Sonork: whats this?! Thanks Meter: 316 | Quote:
flash with jaf or use this.. if after flash problem is still service lcd connector. | |
The Following User Says Thank You to Y.P.Y For This Useful Post: |
03-19-2010, 16:03 | #4 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: 00000000h Age: 42
Member: 43548 Status: Offline Thanks Meter: 2,192 | Quote:
will be better if you specify what BOX u used. also, with latest version (dont forget to make partial-update) try to flash with 'Fast Flash' checked, this is recommended for newer phones. BR. | |
03-19-2010, 17:29 | #5 (permalink) | |
Member: 1003310 Status: Offline Thanks Meter: 28 | Quote:
The Box is none other than HWK UFS (mobileEx_ver v3.3_rev1.6) Last edited by realtech; 03-19-2010 at 17:38. | |
03-19-2010, 18:37 | #6 (permalink) |
Member: 1003310 Status: Offline Thanks Meter: 28 | Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010) Processing file: rm411__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 19.92 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 17AA68FB [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 17AA68FB Bootstrap failed! Flashing terminated with error(s) in 3.844 s |
5220 rm-411 show nokia than off | himanshu taldar | Nokia Base Band 5 ( BB-5 ) | 13 | 10-22-2010 16:15 |
Nokia 5220 RM-411 goes to white screen | realtech | HWK | 9 | 04-20-2010 11:01 |
<<< Nokia 5220 RM-411 Contact Service Repairing >>> | khadim100 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 02-03-2010 12:59 |
Nokia 5220 rm-411 always say sl3 phone, not supported | sahil2000ind | MT-BOX | 4 | 12-17-2009 19:29 |
Nokia 5220 RM-411 rigtone problem | kad-kad | Nokia Hardware & Hardware Repair | 0 | 12-21-2008 11:13 |
