05-03-2013, 10:23 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | 2690 contact server Using device: HTI, FW ver: 00.50, SN: 01012F93 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed phone is dead when conect wit charger it says contact server, wat must be the problem here, plz helpp |
05-03-2013, 16:04 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Your Phone is having short or Leaked Power IC, Means change BETTY IC will solve it, If not solve, then change AVILMA IC. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
