Old 08-02-2012, 05:58   #1 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow Nokia 5233 after full flash still on vibration
GOOD MORNING TO ALL GSM MEMBERS
i have a Nokia 5233 first take backup then full erase this is my mistake
now set is dead i have latest version with same product code but hand set still on vibration any expert give me solution if have i,m very thank full to all my helpers
The Following User Says Thank You to 6622622 For This Useful Post:
Old 08-02-2012, 06:11   #2 (permalink)
Member: 1454923
Thanks Meter: 9
show logs og rpl and simlock etc
Old 08-02-2012, 13:20   #3 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow After erase set dead
Old 08-02-2012, 13:27   #4 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
now i m bzy but i have special for u if u fail but first try to erase it maually come at sonorok if u not get erase file try maually erase via file may be u undestand
Old 08-02-2012, 13:32   #5 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow
i do it with manually erase file but result are same
Old 08-02-2012, 13:49   #6 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
just needed 2 min no more problem try it via infinity best dongle otherwise contect with me
Old 08-02-2012, 13:55   #7 (permalink)
Member: 161280
Sonork: 100.1616990
Thanks Meter: 82
try to download this file and do full flash 51.9.002
Old 08-02-2012, 14:08   #8 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Thanks Meter: 505
tis set come this problem with ERASE.
problem is flash chip not erase fully but with some erase file can do something
u need t try, this situation ur set can be brick.
B,R-
Old 08-02-2012, 15:25   #9 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow
bro already flash with 51.9.002.....
Old 08-02-2012, 16:03   #10 (permalink)
Mirtelecom's Avatar
Member: 1754881
Sonork: 100.1644926
Thanks Meter: 146
good morning to all gsm members
i have a nokia 5233 first take backup then full erase this is my mistake
brother if us setting is ok and after full flash local mode on display comes,then no problem just flash your handset with same product code your problem 100% solved
Old 08-02-2012, 16:30   #11 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
no show local mode on display & UI setting not ok
Old 08-02-2012, 16:56   #12 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. What you done before leave it, again follow Erase Method from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ with Nasty Uni Erase File attached below will erase full Flash Chip.
Use FiRe Agent & Download Latest Firmware of your Phone with same Product Code of your Phone, can check Battery Back for the same.
After Flash Write Full PM then Restore IMEI, Click Buscheck & post Logs as well as Result for the same.
BR,
ZUBER
File Type: rar mobileex_NAND_uni_erase_BB5.XSR1.rar (384 Bytes, 381 views)
Old 08-03-2012, 05:43   #13 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
go to quick fix tab:
tick on bb5 sw downgrade fix & bb5 rap3nand erase user area, then click on do seleected jobs
good luck bro
br
Old 08-03-2012, 07:43   #14 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
Arrow
good luck bro
br
Old 08-03-2012, 07:48   #15 (permalink)
6622622's Avatar
Member: 1562066
Sonork: 100.1622824
Thanks Meter: 555
BR,
ZUBER
dear bro i have same flash file with product code when no success in full flash then how to give full pm plz explain
Page generated in 0.26223 seconds with 10 queries
