09-21-2011, 14:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2004
Member: 60993 Status: Offline Thanks Meter: 22 | nokia 5233 phone startup failed contact retailer ## (ANSWERED) boot on usb it log on mxkey Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 14C6FE5B CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0A100104488C0052B8A71C91E72AECA306A8C5C5 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 software will stop here ----------------------------------------------------------- hwk show this USB BOOT : 60,07 [Rm-625] [2.2.0.2] CMT ASICID: 000000010000022600010006400C192101051105 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 0A100104488C0052B8A71C91E72AECA306A8C5C5 CMT MODE : 00 CMT HASH : B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROMID : 4B9B75103E691FF8 CMT 2ND Bt: RAPIDOv11_2nd.fg, Ver: 11.16.0 CMT 2ND Bt: SILO OK CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00EC0040-00000231, Sam OneNAND-2G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : RAPIDOv11_XSR17_alg.fg, Ver: 11.16.0 ERR: CMT ALG Boot CERT_REQ Fail Rebooting Mobile how to solve it pls help me. |
09-21-2011, 14:45 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Mate it is new hash phone you can not Fbus check with UFS or JAF Interfaces use MX-BOX HTI or ATF and for your Contact the Retailer problem post Scan log to see its security status and give you correct solution. WBR |
09-24-2011, 04:19 | #7 (permalink) | |
Freak Poster Join Date: Sep 2011
Member: 1652081 Status: Offline Sonork: 123456 Thanks Meter: 86 | Quote:
01-07-2013, 09:56 | #8 (permalink) |
Junior Member Join Date: Jan 2009
Member: 937627 Status: Offline Thanks Meter: 3 | Phone type: RM-625 (Nokia 5233) SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia ApeCoreSw: V 51.1.002 Imei plain: 35861404202034-3 Battery voltage: 4459 mV, current: 203 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
01-07-2013, 11:59 | #10 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
If you have Backup Simlock, then Restore, Else Buy Factory RPL. BR, ZUBER | |
04-20-2013, 15:18 | #11 (permalink) |
Junior Member Join Date: Aug 2008
Member: 843639 Status: Offline Sonork: 73663:britco Thanks Meter: 0 | 5233 flashing fail..only vibra Nokia 5233 was on and I took the RPL and PM backup in ATF.my atf ver 9.71 5233 sw version..51.9.002. Then erased and flashing done. But it shows waiting for to on phone..max 150 sec..but it is not booting up..If i am doing bus checkup after flashing it get scanned..Then I wrote RPL ..But when trying to write PM.it cannot get scanned..means fail to write pm..Now it is only Vibra Kindly help me... |
04-20-2013, 17:52 | #12 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
04-22-2013, 06:59 | #13 (permalink) | |
Post Buscheck Logs only if you using Mxkey Apps., Follow Mxkey Rules & don't ask help with other Tools: http://forum.gsmhosting.com/vbb/f550...ection-984366/ BR, ZUBER | |
