10-22-2012, 11:39 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | nokia 5235 (RM-588) can't powerON after erase&reflash i made erase using mobileex_NAND_uni_erase_BB5.XSR1.fpsx file. going via tutorial i made reflash to 51.0.002 (tried via usb and fbus) but phone didn't powerON just bzzzzz. of course i can reflash it now no problem also erase etc just can't powerON after reflash to write PM and RPL backup maybe i should use another erase file correct for nokia RM-588 5230/5235 first log is from erase and second log is from flash. both logs are from flashing via USB but i tried to flash via FBUS too: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C08XXXXX Using device: USB ROM and HTI, FW ver: 00.50, SN: XXXXXXX Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Processing MCU file: mobileex_NAND_uni_erase_BB5.XSR1.fpsx [BB5,XSR 1.6] size: 409 Bytes Supported Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B700001AD9B005260BC318AB14967F834789246 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Partitioning.... Partitioning complete Erase size: -16777225 Bytes CMT FLASH,MuxOneNAND area [00000000-00FFFFFF] CMT FLASH,MuxOneNAND area [00000000-01FFFFFF] CMT FLASH,MuxOneNAND area [00000000-03FFFFFF] CMT FLASH,MuxOneNAND area [00000000-07FFFFFF] CMT FLASH,MuxOneNAND area [00000000-0FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-1FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-3FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-7FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-FFFFFFFF] Flash programming ... Programming completed in 0.010 s Total time for flashing process(boot+erase+write) was 10.272 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C00052D Waiting for USB device removal ...OK Waiting for USB device arrival ...Aborting operation ... Warning: Phone did not reboot to normal mode. Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0XXXXX Using device: USB ROM and HTI, FW ver: 00.50, SN: 00XXXXX Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Processing MCU file: RM-588_51.6.002_prd.core.C00 [BB5,XSR 1.6] size: 102.79 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B700001AD9B005260BC318AB14967F834789246 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 44.590 s Processing PPM file: RM-588_51.6.002_prd.rofs2.V06 [BB5,XSR 1.6] size: 23.93 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 37.75 MB CMT FLASH,MuxOneNAND area [06BA0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 25.762 s Processing PPM file: RM-588_51.6.002_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 6.900 s Processing CNT file: RM-588_51.6.002_000_001_U001.uda.fpsx [BB5,XSR 1.6] size: 18.56 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 20.940 s Total time for flashing process(boot+erase+write) was 2 min 50.727 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... |
10-22-2012, 12:55 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Erasing or Downgrading is not Problem, The only reason for not Power ON is you Flashed with Mismatch Version, So use FiRe Agent & Download your needy Version, but must be of Same Product Code of your Phone, If not available in your needy Version, go for more Lower Version, but must be of Same Product Code of your Phone, Now Apply Erase Method again & Flash with my mentioned Firmware, Phone will be Test Mode sure, You can now Restore IMEI & other Certificates. Best of Luck. BR, ZUBER |
10-22-2012, 13:09 | #3 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C08XXXXX Using device: USB R MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C08XXXXX Using device: USB ROM and HTI, FW ver: 00.50, SN: XXXXXXX Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Processing MCU file: mobileex_NAND_uni_erase_BB5.XSR1.fpsx [BB5,XSR 1.6] size: 409 Bytes Supported Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B700001AD9B005260BC318AB14967F834789246 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Partitioning.... Partitioning complete Erase size: -16777225 Bytes CMT FLASH,MuxOneNAND area [00000000-00FFFFFF] CMT FLASH,MuxOneNAND area [00000000-01FFFFFF] CMT FLASH,MuxOneNAND area [00000000-03FFFFFF] CMT FLASH,MuxOneNAND area [00000000-07FFFFFF] CMT FLASH,MuxOneNAND area [00000000-0FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-1FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-3FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-7FFFFFFF] CMT FLASH,MuxOneNAND area [00000000-FFFFFFFF] Flash programming ... Programming completed in 0.010 s Total time for flashing process(boot+erase+write) was 10.272 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2C00052D Waiting for USB device removal ...OK Waiting for USB device arrival ...Aborting operation ... Warning: Phone did not reboot to normal mode. |
10-22-2012, 13:11 | #4 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | this is rm-588 product code 0585610 i reflashed it with firmware for same product code this is log from flashing: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C08XXXX Using device: USB ROM and HTI, FW ver: 00.50, SN: 000XXXXX Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Processing MCU file: RM-588_50.0.001_prd.core.C00 [BB5,XSR 1.6] size: 106.42 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1B700001AD9B005260BC318AB14967F834789246 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 46.474 s Processing PPM file: RM-588_50.0.001_prd.rofs2.V06 [BB5,XSR 1.6] size: 23.93 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 33.50 MB CMT FLASH,MuxOneNAND area [06FE0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 23.590 s Processing PPM file: RM-588_50.0.001_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 6.022 s Processing CNT file: RM588_50.0.001_000_000_U001.uda.fpsx [BB5,XSR 1.6] size: 18.55 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 19.440 s Total time for flashing process(boot+erase+write) was 2 min 44.269 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Warning: Phone did not reboot to normal mode. |
10-22-2012, 13:19 | #6 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 55 | i flashed via USB and FBUS but same problem. during USB flash i didn't saw this info about nand but during flash via FBUS i see this: Code: Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... |
10-22-2012, 14:22 | #7 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Don't ask for Files of External Links, You already Half Bricked your Phone, Doing unusual Experiments will Brick Completely. BR, ZUBER |
10-22-2012, 14:36 | #8 (permalink) | |
Member: 27761 Status: Offline Thanks Meter: 55 | Quote:
Also i didn't do anything special just put mobileex file for erase and flashed several times but phoen don't powerON. i see this info only during FBUS flashing, USB flash without such info. Of course Fbus flashing finished OK just phone can't power ON could you give some light to that info, is it main problem with restarts after flash to new version and main reason phone can't power on now after falsh: Code: Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... | |
10-22-2012, 15:20 | #10 (permalink) | ||
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
I deleted Links, want to save your Phone, Am still searching RAPIDO Erase File on my PC for you, But don't think will work much here. Quote:
1- Hardware: Reflow or Reball Flash IC & repeat Flash Program may appear Test Mode, 2- Software: Applying Erase Method in proper way, (feel Very Risky even never failed) can Solve it. 3- Possible Half Dead Flash IC, where only Replace is option. BR, ZUBER | ||
10-22-2012, 15:45 | #12 (permalink) | |
Extract it in Mxkey Folder, Use FBus Cable, Go to Advance Tab > Untick Safe Erase > After Erase Fill only MCU with this UNI Erase File & Click Flash, Now Phone is Fully Erase, Flash it with Version 51.0.002 Firmware, Restore All as-usual & post result. BR, ZUBER | |
09-25-2013, 16:38 | #15 (permalink) |
No Life Poster Join Date: Feb 2003 Location: EAST AFRICA! TANZANIA
Member: 22893 Status: Offline Sonork: 100.1607086 Thanks Meter: 131 | @::ZUBER:: MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0881C0D Using device: HTI, FW ver: 00.50, SN: 01013C5C Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 0780000140A10052601F09AB5B2A20DC14B0ABB0 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Processing MCU file: RM-588_20.0.005_prd.core.C00 [BB5,XSR 1.6] size: 102.28 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Storing certificate [NPC, CCC, HWC, R&D] ...ERROR: Packet Error(0xAA), code 0xA4000002 Error Erase size: 154.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Error while erasing, Result: 00000000000000 , 0 What can i do ffor this? |
